Question about Linksys WRT54G2 Wireless Router
Want to modify my settings - Linksys WRT54G2 Wireless Router
    Sergeant:
  • 257 Answers
Documentation is at
http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G2
But this page is way more helpful
http://www.pcwintech.com/wireless-setup-linksys-wrt54g2-linksys-firmware
From a browser enter 192.168.1.1
This should give you the web interface to your router.
Your interface should look something like this:
http://ui.linksys.com/files/WRT54G2/1.5.00/
To login leave user id blank and use 'admin' as a password (default)
Note that this model has at least 3 different variants and particulars will vary:
http://en.wikipedia.org/wiki/Linksys_WRT54G_series#WRT54G2
Posted on Jan 11, 2011
6ya staff
SOURCE:
How to adjust the water pressure on a smart head Pentax pump?
To modify the pressure:
· Start the pump.
· If the SET LED blinks, hold key + down until the SET LED
remains on.
· Then press keys + or - to modify the pressure value
Oct 09, 2018 | Plumbing
Tip
How to set, modify, remove and recover Excel 2007 password?
Microsoft Office software developers have been paying more and more attention to the means of protecting users' information, and Microsoft Excel has not been overlooked. Recent versions of the program provide users with advanced features for protecting Microsoft Excel documents against unauthorized access of the information stored in them. The methods include completely blocking access to a document, forbidding saving changes to it. Besides, some expert team even designed Excel password recovery tool to recover Excel 2007 password for those who have lost Excel password.
Set a password to open or modify Excel 2007 password Set a password to open Excel 2007
  1. Click the Microsoft Office Button office.gif , point to Prepare, and then click Encrypt Document. excel-document.gif
  2. In the Password box, type a password, and then click OK. You can type up to 255 characters. By default, this feature uses AES 128-bit advanced encryption. Encryption is a standard method used to help make your file more secure.
  3. In the Reenter password box, type the password again, and then click OK.
  4. To save the password, save the file.
Set a password to modify a Excel 2007 Spreadsheet In addition to setting a password to open an Excel spreadsheet, you can set a password to allow others to modify the spreadsheet.
  1. Click the Microsoft Office Button office.gif , click Save As, and on the bottom of the Save As dialog, click Tools.
  2. On the Tools menu, click General Options. The General Options dialog opens.
  3. Under File sharing, in the Password to modify box, type a password.
  4. In the Confirm Password dialog, re-type the password. Click OK.
  5. Click Save.
Remove password protection from an Excel spreadsheet
  1. Use the password to open the spreadsheet. (Note: If you don't know the open password, you have to recover Excel password with the third Excel password recovery tool)
  2. Click the Microsoft Office Button office.gif , point to Prepare, and then click Encrypt Document.
  3. In the Encrypt Document dialog box, in the Password box, delete the encrypted password, and then click OK.
  4. Save the spreadsheet.
Recover Excel 2007 password with Excel Password Unlocker Excel Password Unlocker is a popular Excel password recovery tool that can recover Excel password from Excel 97 to Excel 2007
Related Office 2007 document password tips:
How to set, modify, remove and recover Word 2007 password?
How to set, modify, remove and recover PowerPoint 2007 password?
on May 21, 2010 | Computers & Internet
I unplugged my maf on my 2005 mustang have mods on car still idle pretty rough put maf back in the car died why
Because the PCM went into default mode when you unplugged it. When you plugged it back in, the PCM tried to adjust and reset. Opening the IAC motor causing to much air to come in and killed the engine. Fairly normal response for the engine. Since you modified the engine, did you modify the PCM? Can't do one with out the other.
Apr 10, 2015 | 2005 Ford Mustang
In Restaurant Pro how do I change settings so that each item will appear on a separate line? ie....someone orders a greek salad with a modifier, on same tab another greek salad with no modifiers. The
Hi Judy,
You probably have it set to combine lines on invoices. Go to your options screen. Select SETUP, then SETUP SCREEN. Click the INVOICE SETTINGS tab, then uncheck COMBINE LINES, click UPDATE, then EXIT. Now each item should display on its own line.
If you need further assistance or tech support at reasonable rate, send me line at sysadmin@ccybernet.com
Feb 04, 2015 | Pc America Restaurant Pro Express
Can you modify a Modifier button and Choice buttons or do you have to start a whole new button/s?
Hi Alice,
A choice button just gives you a choice of individual items in inventory. The choice itself is also an inventory item and can be found in inventory by clicking the LOOKUP button, then clicking the CHOICE ITEMS button down the right side. It should be in the list. SELECT it and you can edit the list by adding more items or removing item and then arrange the order they are displayed.
The drinks are probably a modifier group. Generally they are setup under the drink size, then you choose the flavor. These too can be added, removed, extra charge for certain ones.
Feel free to email me with more details if need be. I could give you a training class on this if desired.
Jun 20, 2013 | Pc America Restaurant Pro Express
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
Please, give me suggestion to modified my motorcycle pulsar 220..or you have pictures after modified...thanks
Hi, Jelou_lee for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
Bajaj Pulsar 220F modified exhaust adjustable levers
Pulsar 220 Modified By Kaulson Racing KRP
Service Manual Bajaj Pulsar 220
http://www.tunasmegaspirit.com/files/catalogue/Pulsar-220-Spareparts-Catalogue.pdf
https://www.facebook.com/media/set/?set=a.504541669580494.120586.177568422277822&type=3
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 11, 2011 | Bajaj VL50E Motorcycles
R1 signaling and R1 modified signaling
R1-Modified enables/disables a modified version of R1 signaling (described in the ITU recommendation Q.310-332) that is required in Taiwan. Only set this option to "yes" if the unit is located in Taiwan.
Aug 04, 2009 | Lucent Ascend Series56 Digital Modem...
Cannot modify my privacy settings
Clear all your cookies,temp net files. allow all cookies and try again.
Jun 01, 2009 | Facebook Social Network
'Choice or Pass Along Items'
you might mean modifiers, that's what i'd usually set up. there are choice items too though but i think modifiers are most useful for restaurants.
Modifiers: http://faq.pcamerica.com/file-lockers/pdf-locker/Creating_modifiers.pdf
Mar 02, 2009 | Pc America Restaurant Pro Express
Linksys WRT54G2 Wireless Router Logo
210 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
