SOURCE: Photo Paper Jams
Based on your question, my first thought is that you changed the type of photo paper you used starting "this week" (when you first posted your question). If you did, the photo paper size/thickness may not be compatible with your printer.
Otherwise, there may be a problem with the paper sensor. Click on the following link and review the troubleshooting steps, particularly Step 2, to see if that helps:
Paper Jam Troubleshooting
Post back your results. If you are still having the problem, post any additional information you think might help solve the problem. Thanks and good luck.
SOURCE: paper jam in dell photo 964 . Took all the paper
Hi there
i have the exact same printer and this is what i did even though i took out all of the paper ( i thought) i got a flashlite and i opened up every thing that i could and then i looked and wow lots of little pieces of dust and some paper too so i removed all of that and after powering it up again it worked just fine so you may want to try that ok hope this helps solve your problem.
best regards mike
SOURCE: Will not accept photo papaer
It means that it will not support oil or photo paper...i think it will support A4 or smaller only
SOURCE: Epson stylus DX3800 All in one printer, scanner Unable to print
Do a printer check by copying on standalone. means placing a document
inside the scanner. Load 10 sheets of regular paper into the feeder
then press the start button to begin copying. Try 2 copies. If it gives
you the same error, then there is already an issue with the gear inside
the printer.
If your unit is not under warranty anymore, log on to
support.epson.com. Click on help me find a service center to the right
of the page. You will have to put in your zip code to find an epson
certified servicer near to your area.
If your unit is not a year old yet, please call epson technical support.
If
it copied successfully, it could be just the paper settings, or the
type of paper that you are using is not supported or you might have to
uninstall and re-install drivers.
Try the above steps and reply me. Thank you Sir, Have a nice day.
Testimonial: "Thanks for replying so quickly.It still has not printed or sucked any paper in.I'm sure it must be the gears inside.Maybe just worn out?"
SOURCE: my polaroid pogo wont print
when printing make sure that the paper is inserted in the pogo shiny side up and logo facing down. also try putting through the blue alignment sheet first as the pogo will not work without this. hope this helps
