This is a link to view how to reset: http://www.youtube.com/watch?v=Qzc9JImUcak
This is a link to download firmwares (version 1.13, 1.16, and 1.18_fix)
and download software to update firmware files to printer:
http://dox.abv.bg/files/listtree
MOST IMPORTANT:
1. Push 8 times button MENU then OK to print a report and view your version of firmware
2. REPLACE FIRMWARE VERSION 1.13 ONLY WITH 1.13_fix
3. REPLACE FIRMWARE VERSION 1.16 ONLY WITH 1.16_fix
4. REPLACE FIRMWARE VERSION 1.18 ONLY WITH 1.18_fix
5. REPLACE FIRMWARE VERSION 1.21 ONLY WITH 1.18_fix
6. DO NOT REPLACE FIRMWARE VERSION 1.23, I DON'T HAVE FIRMWARE VERSION 1.23
IF YOU REPLACE FIRMWARE VERSION WITH WRONG VERSION A "SCANNER ERROR"
OCCURS AFTER SEVERAL MONTHS WHICH MEANS YOUR SCANNER MATRIX IS BURNED
OUT AND MUST BE REPLACED
GOOD LUCK!
Yes also
SOURCE: samsung scx-4300 toner exhausted
Have you replaced the toner? If not then doing so will reset the message. If you have, and the message remains, then was it a remanufactured/compatible unit? Probably the toner reset fuse has not been installed on the cartridge (or is defective)
SOURCE: how to reset samsung scx 4300 printer cartridge
you can not reset this chip change it you must be buy a new one cartridge
SOURCE: how to reset toner counter of samsung SCX-4300
how to reset samsung scx 4623F?
Thank so much!
SOURCE: Toner Exhausted Replace Toner" scx-4300
Hi
You need to raplce chip on cartridge
Pls vote me to keep me alive
toner empty
