Hi, In order to find the wireless security password of your Dlink wireless router G WBR-2310 , please follow these setps 1. Open up the internet explorer in the computer in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter. 2. You will be logged into the D-Link router setup page . 3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless security Mode under which you can find the password for the wireless settings. Good Luck! Thanks in Advance! With Regards, Prema.
You need to access the web-based configuration utility first.
- Open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1).
- Enter the user name (admin) and your password. Leave the password blank by default. If you get a Page Cannot be Displayed error, restore your router to its original factory
default settings by pressing the reset button, then try again.
- After login into the web-based configuration, Click on Wireless Settings on the left side.
- Next to Security Mode, select Enable WEP Security. Enable WPA-Personal Security or Enable WPA2-Personal Security.
1/ For WEP Security, Next to Authentication, select Shared Key.
- Select either 64-bit or 128-bit encryption from the drop-down menu next to WEP Encryption.
- Next to Key Type, select either Hex or ASCII
Hex (recommended) - Letters A-F and numbers 0-9 are valid.
ASCII - All numbers and letters are valid.
- Next to Key 1, enter a WEP key that you create. Make sure you enter this key exactly on all your wireless devices. You may enter up to 4 different keys.
- Click Save Settings to save your settings. If you are configuring the router with a wireless adapter, you will lose connectivity until you enable WEP on your adapter and enter the same WEP key as you did on the router.
2/ For WPA-PSK configuration
- Next to Security Mode, select Enable WPA-Personal Security or Enable WPA2-Personal Security.
- Next to Cipher Mode, select TKIP, AES, or Auto.
- Next to PSK/EAP, select PSK.
- Next to Passphrase, enter a key (passphrase). The key is an
alpha-numeric password between 8 and 63 characters long. The password can include symbols (!?*&_) and spaces. Make sure you enter this key exactly the same on all other wireless clients.
- Enter the passphrase again next to Confirmed Passphrase.
- Click Save Settings to save your settings. If you are configuring the router with a wireless adapter, you will lose connectivity until you enable WPA-PSK (or WPA2-PSK) on your adapter and enter the same passphrase as you did on the router.
Hope this help! You can download the user manual by clicking this link: http://www.netwood.net/support/manuals/D-Link_WBR2310_manual_10.pdf
SOURCE: dlink wbr-2310 router no wireless working
you have to change your channelk type in your wi fi router.
For that access your router with following link
http://192.168.1.1 or
http://192.168.0.1
if you have belkin router
http://192.168.2.1
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
Thanks for using fixya.
Please rate this solution if it helps.
