It sounds as if the fan has ceased working. If it is freezing the bottom, then the refrigerant has not escaped. If it was the compressor, the motor would have become louder and begun to rattle. If you can turn it off for a day, then turn it back on. If the fan motor starts to work, it may just have been frozen up, replace your seals . If the fan motor does not start then well it will not. Try replacing the fan motor.
SOURCE: Haier 4.6 stainless steel fridge...
Check the thermostat. make sure it is turned on. The thermostat can shut it off. Also check to see if you have power to that outlet you are using. If none of that is the problem you can try and bypass the thermostat with a jumper wire( If you are comfortable with do this) Be careful when doing this cause electric shock is possible. don't touch any wires directly
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
heatman101
