Question about GPX HT119B Theater System
Hi I have a GPX Home Theatre System model # HT119B all of a sudden there is no sound from the subwoofer. I can't find my manuel and everything seems to be connected properly..there is sound comin from the 2 speakers. Thank you. Janet
    Brigadier General:
  • 8,546 Answers
Anonymous
SOURCE:
Hi, My Sony DVD Home Theatre suddenly shows NTSE
hi,
press the display button on the remote control, go to custom settings. then select video settings. in that menu select the system setting, change it to PAL.
ok
Dec 27, 2010 | Sony DAV-DZ720 Theater System
Hi I have just purchased a Panasonic Plasma TV and Panasonic home theatre. Everything works well except for I cannot get sound coming out of the home theatre when watching normal TV. I purchased the...
Try running the audio from each video source (NOT the TV, which is an output, not a source) to the HTR digitally so you'll get the best mutichannel sound possible. Then you can turn the TV speakers (assuming it has them) off for hi-end watching.
Aug 15, 2010 | Panasonic Audio Players & Recorders
Home Theatre system goes into MUTE mode while film playing
Sounds like your system is going into a safe mode. This happens when you have a neg/pos reversed hooked up, or your wires are touching. This feature prevents you from blowing up your amp. Check your wires, and make sure the positive is hooked to positive etc. and make sure no bare wires are touching.
Sep 01, 2009 | Audio Players & Recorders
Problem with sound - Philips HTS3455 Home Theatre System
Hi, I am sorry to say that there is probably a fault. First check the fuses if able (a possibilty). If not that then will need to go in for repair.
Hope that helps
Jul 24, 2009 | Audio Players & Recorders
Connection/sound issues!
the best thing to do is if ur lcd has a phono in/out is to connect ur theatre system through phono straight to the tv as then everything that comes up on the tv comes throught the theatre system
Feb 10, 2008 | Sony DAV-IS10 System
Connet to pc
Well, I would have to know what connectors your sound card and home theatre system have. If you dont have a sound card, get a headphone/3.5mm trs plug to stereo rca plug adapter usually available at your local radio shack or walmart, and connect to the red/white rca plugs on your reciever. If they have other connectors(your sound card/ home theatre system) you might try coaxial digital audio-S/PDIF or optical S/PDIF.
Dec 25, 2007 | Durabrand HT-3915 System
HOME THEATRE SYSTEM
I think you must change the settings and try it out! it will make a great change.
Dec 07, 2007 | Audio Players & Recorders
GPX HT119B Theater System Logo
124 people viewed this question
Top GPX Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
