Question about Logitech Harmony 880 LCD Remote Control
Using Harmony 650 remote by Logitech. Works fine for TV, DVD and partially works for Roku (Netscape streaming, etc.)...But when using the Roku, the new remote does not control the volume nor does the Mute button work. Any ideas.
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
If you have an infrared remote and your Direct Tv remote is using an RF signal then you need to call Direct Tv and they will help you program your DVR to the remote.
Posted on Dec 30, 2008
Anonymous
  • 24 Answers
SOURCE: I like to program in my Roku box for streaming
You can download the software to program your remote from the site below.
When adding devices, the Roku is listed under Satellite Receivers. I have a Harmony 880 and recently programmed it to add a Roku.
http://www.logitech.com/index.cfm/440/2984&hub=1&cl=us,en?osid=13
Posted on Nov 03, 2009
Minoru
  • 8 Answers
SOURCE: I need instruction to dissasembly the logitech harmony 550
It´s very simple to disassemby it, you need to force with a little screwdriver as shown in these images. 20b34c1.jpgf933c6b.jpg79788d2.jpg0aa041e.jpg64cc0aa.jpgd49680d.jpg8ec64e0.jpgb5f5e97.jpg46665e8.jpg
Posted on Jan 26, 2010
Anonymous
  • 101 Answers
SOURCE: logitech harmony 550 volume problem
I would call or email in to logitech and suggest that they copy some of the learned commands for your bose system into your harmony remote account.
The commands they add are learned from other customers and they will only copy the best ones. Give it a shot.
Posted on May 06, 2010
How can i gen my harmony 650 to work with a kogan tv?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 03, 2014 | Logitech Harmony 650 Remote Control
Harmony will not pick up sound from Bose, for TV
Advanced remote controls such as your Harmony can be programmed with a macro to automatically execute a series of commands. What you need to do is work backwards through the automatic sequences to separate functions you wish to control manually (such as volume).
Jul 01, 2014 | Logitech Harmony 525 Advanced Universal...
Logitech harmony 650 remote doesn't work with old Roku player
I have an old Roku and was able to get the harmony 650 to recognise it. The model of my old Roku was SD since I originally used it on my analog TV. Everything seems to work without having to "teach" the Harmony. The only quirk was having to use the Exit button to go back to a Netflix movie description and again to go back to the channel list.
Jan 15, 2012 | Logitech Harmony 650 Remote Control
Remote will allow you to "choose an activity" to
Hi. It sounds like some of the IR commands on your remote (menu, exit, guide, info, play, skip, etc.) for your TV and DVD player are not correct. Luckily, the Harmony remote is a Learning remote, meaning you can use your original TV or DVD player remote to teach the Harmony remote the correct commands. The following tutorial by Logitech will assist you with this:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=3859
Regards,
D
Aug 26, 2011 | Logitech Harmony 890 LCD Remote Control
I have a harmony 890. it turns all the equipment on/off properly except the TV (a Vizio). this works intermittently. suggestions?
Hi. Try learning the power commands for your Vizio TV from the original remote. The power commands that the Harmony remote is using may not be correct. The following tutorial by Logitech will assist you with this.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9605
Regards,
D
Can't get Roku N1100 to work with Samsung LCD. Worked fine with older style TV. DVD input works fine. Connect Roku....Nothing. Samsung LN32C350. Attempting to connect with RCA style connectors,...
Make sure you select the correct input for your device. If you are using RCA cables then select the RGB option on your inputs, or it may RCA as a connection. If you are using HDMI then make sure that is selected.
Dec 07, 2010 | Roku HD Player (N1100)
I like to program in my Roku box for streaming movies to my Harmony H628 any one know he program number/steps
Nov 01, 2009 | Logitech Harmony 880 LCD Remote Control
I need the Harmony Remote Software for programming to my new TV
Go to this link on the Logitech web site and download the operating software and follow the instructions. Easy peezy.
http://www.logitech.com/index.cfm/440/371&cl=us,en?WT.ac=sc|downloads||dd
Apr 02, 2009 | Logitech Harmony 520 LCD Remote Control
Cannot get DVD to play movies -
I can help you with your Logitech Harmony 890 remote control.
The Logitech Harmony 890 remote control is programmed through the
Harmony Windows Setup Software.
Once installed, you will simply run the program and select the devices you would like to control from menus. This program finds the right codes for you and loads them into your remote control.
You can get a copy of the Harmony 890 Manual by clicking here.
I hope that helps.
_____________________________________________
Harmony 890 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Harmony MAC Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Feb 02, 2009 | Logitech Harmony 890 LCD Remote Control
Can't control DVD functions from remote
absolutely ridiculous. i ran into this problem too.
Mar 01, 2008 | RCA L26WD26D 26 in. LCD TV
Logitech Harmony 880 LCD Remote Control Logo
241 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
ray gallant
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
