Dell PowerEdge 1800 Server Logo
Anonymous Posted on Jan 10, 2011
I have a blue vertical flashing light showing just above the Dell emblem. In the past there has been a solid light. I have checked on OpenManager which indicates all is well but I do not like unexplained changes on servers. Can anyone give me any guidance please? Thank you Ian
  • Chris
    Chris Jan 10, 2011
    Hi Ian,
    I don't remember the exact layout of the poweredge lights as I've been working mostly with HP servers lately. Can you either snap a pic of the area around the blue light or describe the symbol below and beside so I can refresh my memory.
    BTW, none of us like unexplained changes with our servers...
    Chris
  • Anonymous Jan 10, 2011
    Hi. Thanks for your response. Unfortunately I cannot take a snap but my best description is that it is a vertical flashing light dead centre vertically, about an inch long just above the round Dell emblem at the top of the drilled holes in the Dell box and just below horizontally where the power switch is and the cd rom drive. I hope this helps
Chris
Level 3:
  • Master 696 Answers
  • Posted on Jan 10, 2011
Chris
Master
Level 3:
Answers
696
Questions
0
Helped
341414
Points
1874
Great thanks,
That's just a system indicator flash. Solid blue means on and normal, blinking means someone either turned on the system indicator in the management software or bumped the indicator switch on the back of the server. This was designed to make easier transitions from back to front when working with multiple servers in a rack. To turn the indicator off, just go to the back of the server and find the Ethernet and usb ports that are together. If the usb is the bottom and Ethernet port is the top then just to the right you should see a small blue blinking light and a button, pushing the button wil turn the blinking off.
Again, no worries this is just a "locator beacon" not an error message, if the light ever blinks yellow then you have an issue.
Hope this helps FixYa,
Chris
Testimonial: "Chris - you are a star! Many thanks"
  • Anonymous Aug 16, 2011
    Many thanks Chris! from AlejandroE
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1568
Points
Mine on a PowerEdge 840 will blink amber when the front panel is removed. Intrusion detection. When I am working on it I place a piece of tape on the front button and it turns blue and stops that stuff.
Flashing led's on battery pack
Charles,
The battery turns on steadily or blinks to indicate battery charge status.
If the computer is connected to an electrical outlet, the light operates as follows:
  • Solid blue - The battery is charging.
  • Flashing blue - The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
  • Off - The battery is adequately charged, or the computer is turned off.
  • Flashing orange - The battery charge is low.
  • Solid orange - The battery charge is critically low
Thank You,
Dell-Jesse L
Dell Social Media and Communities
My dell precision 470 processor fans over speeding
It seems like the processor is overheating. Maybe you need to spread out thermal paste on the CPU.
My dell inspirion 1525's screen is black numerical lock light is onblue,the cap lock blue light is flashing,the download lock light is on blue as well
Hi Friend, In this case if the caps lock is flashing blue and the other 2 LED's are solid blue, this is an indication that there is something wrong with the memory (RAM) itself.
So I would recommend you to please reseat the memory card of the system. I am also sending you the link that will assist you in reseating the memory
http://support.dell.com/support/edocs/systems/ins1525/en/SM/memory.htm#wp1180987
Please reseat the memories. Please let me know if it is of any help.
Hi. i want to check if my dell laptop inspiron
The WI-Fi LED is a sign that its Enabled or ON. The LED light on the side of the switch is called the Wi-Fi Catcher.The light operates as follows:
Flashing blue:
Searching for networks
Solid blue: Strong network found
Solid yellow: Weak network found
Off: No signal found
Please comment if the information has been helpful. Thank you and regards.
11helpful
2answers
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
3helpful
My Dell latitude E6400 does not power on
Try memory modules individually. See if any change.
Also post whether the Lock LEDs are solid or flashing
14helpful
2answers
Blue light flashing
Someone has pushed the system identification button on the front of the server. If you push it again the light will be solid blue.
Help with server boot problems flashing orange lights etc
Seems the RAID is broken. You may see which drive (hot swappable?) it showing an error code with its lights in front. If not, I would suggest re-seated all drives.
If you see one that is not right, remove it all the way, while it is on, then push it back in, it should try to rebuild the raid on the drive, if it still fails, you will need to replace the drive.
Not sure what RAID you are using or how many drives, so feel free to explain more.
G'luck
Power light flash
check the firmware you are upgrading to is supported for the hardware model yoiu are using.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
