As sed above try using the fone with out the memory card..if the problem still persists then try formatting ur fone but all the data would be lost that's in ur PHONE MEMORY[ Not the MEMORY CARD] u can try taking a back up but like u sed fone shuts off again n again im not sure that u would be able to take back up or not. Neways to format ur fone type in on key pad *#7370# then ull get a confirmation saying " RESTORE ALL ORIGINAL PHONE SETTINGS? PHONE WILL RESTART" press yes and the fone will be as new as when u bought from store.SECOND, even after formatting,problem is there u can then finally try upgrading the fone's firmware version by downloading the "SOFTWARE UPDAT SOFTWARE" from nokia's website.im sure this would resove ur problem to ur satisfactino and even after upgradin firmware u can restore ur phone contents i.e IF BYCHANCE U WERE SUCCESSFULL TO TAKE A BACK UP.
DO RATE THE SOLUTION THAT IVE PROVIDED PLEASE.
Just delete the unwanted applications that u have installed in your phone...
If the problem occurs again remove your memory card then scan it using ur system antivirus (Use memory card reader) this will fix ur problem....
