SOURCE: IP address
1. if you computer connected to the internet behind the router you can use this command under dos or command prompt.
ipconfig /all
under internet adapter local are connection look for gateway and thats your router IP address,
2. if you still cant access it .
force reset it to default settings
there's a small reset botton at the back of it, use pen to reset it and it will reset to its default IP address
try:
192.168.0.1<-- this is the default for dlink
192.168.1.1
192.168.1.0
SOURCE: ihave problem iam make my D-Link AirPlus Xtreme G
if the router or modem has wire if wireless if there then they have the same seciurty option it means same passwork wep
SOURCE: how to configure wireless device model tp-link access point p2p
AUTOMETIK CON.CHANGE D-LINK AP 2100 VERY PROBLAMS MY CONTECT NO:- 9939487245
Step 1 Log into the web-based configuration by opening up a web browser and typing in the IP address of the access point (192.168.0.50).
Step 2 The default username is admin (all lower case) and the password is blank (nothing). Click OK.
Step 3 Click on the Advanced tab and then click Encryption on the left side. Select the Wireless Band (DWL-7100AP only).
Step 4 Click the radio button next to Shared Key and then click Enabled next to Encryption. Make sure your other wireless devices are set to Shared Key.
Step 5 Next to Key Type, select HEX or ASCII. You will need to use the same key on all your wireless devices.
· HEX - use 0-9 and A-F only. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response Thanks, Joe
· ASCII - All numbers and letters.
Step 6 Next to Key Size, select the level of encryption (64, 128, or 152-bit).
Step 7 You can enter up to 4 different keys. Select the key you want to use from the Valid Key drop-down.
Step 8 Enter your encryption key. You make this up yourself. If you selected HEX, then enter a key made up of a combination of numbers (0-9) and letters (A-F). For example - A4572BCC19 (HEX).
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
