Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
Posted on Jan 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It seem that my oven is not on when the control panel says that the heat is on.i can open the door and the touch the food container and they are not very hot.its a gas oven,kenmore,30" freestanding sealed burner gas range.
Anonymous
Level 3:
  • Kenmore Master 3,361 Answers
  • Posted on Jan 10, 2011
Anonymous
Kenmore Master
Level 3:
Answers
3361
Questions
Helped
1029261
Points
10654
Replace the oven igniter.
Neff pyrolytic Oven B4652
My suggestion is NEVER EVER use the self cleaning feature. We see questions like yours at least 4 times a week. Locked doors, burned out elements, burnt out fans and even frazzled control boards. The temperature is just too hostile.
The oven is cleaned by heat, at temperatures above normal cooking temperatures. During the cleaning cycle the oven is heated to about 880 degrees Fahrenheit (471° C.). At this temperature, food soils inside the oven decompose, leaving behind a small amount of ash.
There are a few ideas here
https://www.justanswer.com/uk-appliance/65fdd-ra-ce.html
But Neff says you need a Service Call.
https://www.neff-home.com/uk/service/support/ovens/error-codes
Nov 22, 2021 • Neff Ovens
2answers
What are Self-contained racks with cooling?
it looks to me like a wire rack sitting above a solid oven rack that allows things like baked biscuits to cool in the oven with air flow under them when you turn off oven heat and slightly open oven door when letting food cool in the oven .
Mar 18, 2021 • Ovens
2answers
When using the grill in the oven should the door be open or shut
Hi,these days the door is normaly closed,all the best.
Sep 14, 2015 • Ovens
Had 3rd panel installed march 2014-jtp70 30 inches. now nothing is working-only the light and clock are functioning
I never really fixed the problem, but have avoided it most of the time. Tell me if I'm wrong, but when you open the door to pull out your food after cooking, the steam from the food comes up and fries the control panel, right? To temporarily fix (reset), we just flipped the circuit breaker on and off. To avoid it after that, we would hold a cookie sheet at the top of the oven door, blocking the control panel when we opened the door after the food had cooked. This keeps the steam from blasting the control panel and locking it. Instead, the steam goes into the room.
Pretty ridiculous to have to do that, isn't it? :-( I think we're reaping what we so when we outsource our manufacturing to China...
GE oven controls lock after opening door and steam from cooked food comes out
you may find there is some insulating material missing internally as I would imagine steam affecting the front of the control panel
Door wouldn't open after cleaning now the oven won't work
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
7helpful
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2009 • Ovens
1helpful
2answers
My covection oven does not heat up once food is put in
on the gas valve there is an adj. for the pilot size, maybe too small , would try increasing the pilot and see what happens.also the thermocouple might be on the way out ,you might want to replace that and try oper. go with thermocouple first, then try pilot size dont forget to vote tks. monomoy
10helpful
2answers
F-24 error, beeping after use - Thermador C302US
error code f24 oven shuts down while baking if i open the door and beeps continuously
2helpful
2answers
How to remove the control panel on Whirlpool double oven Model RBD305PDS14
Remove the doors by turning toward you a little toggle apparatus located on each hinge. Locate a small screw on the lower inside edge of the left and right hand trim and then slide off the trim. Remove the lower trim then raise the upper trip and put the left end of the panel inside the top opening. This allows you access to the control panel. Test both the keypad part #8300440 and the control panel part #830219 to see which one needs to be replaced. Order the replacement part, plug it in, reverse the precess above and it should work like new..
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
