Epson Perfection V500 Flatbed Scanner Logo
Posted on Jan 09, 2011
I'm trying to install my new Epson Perfection V500 Photo Scanner. I followed the instructions. The software installed . When I turned on the switch a loud grinding noise occurred and t I get an orange/red light blinking. I uninstalled all the software and re-installed the software again. Again, the same thing happened when I turned on the switch. I am using Windows 7 64-bit OS. Can you please advise. Thanks, Sandy Landers
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 17, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
885
Points
Its the lock mechanism under the lid , lift the top to the scan bed and look at the lower right hand side of the inside of the lid there is a grey swithch , move it to unlock! Voila , fixed.
Epson v500 Photo scanner was working but now gives a red light and whirring noise when opening the app installed on Mac - gives warning "cannot properly connect with scanner".
Here are some troubleshooting steps you can try for your Epson V500 Photo scanner: Check the connections: Ensure that your scanner is properly connected to your computer and turned on. Check the cables and ports for any damage or loose connections. Restart your computer: Sometimes, restarting your computer can fix communication issues between your scanner and computer. Reinstall the scanner software: Try uninstalling and reinstalling the scanner software on your computer. You can download the latest software from the Epson website. Check for updates: Make sure that your scanner software and computer operating system are up to date. Try a different USB port: Plug the scanner into a different USB port on your computer and see if it makes a difference. Reset the scanner: Turn off the scanner and unplug it from the power source. Wait a few minutes and then plug it back in and turn it on. If these steps don't resolve the issue, it's possible that there may be a hardware problem with the scanner that needs to be repaired.
Epson Perfection V500 Photo scanner cover will not close
Check to see if the cover open switch is stuck or the is anything blocking the closing motion, rectify.
I get 2/3rds of the way into installing the software and driver with the set-up disc that came with the Epson V500 Scanner, then a Error Pop Up message appears saying the following. Could Not Copy...
Check that it is installing to the correct file. Normally C Drive "Program files" I would suggest you go to the control panel and locate and completely uninstall the Epson scanner program first. This will give you a clean install. Check that during the installation, the disc may ask where you want the program to be installed. If it has a suggestion, let it instal itself, where it thinks is best.
Software installed successfully. Scanner will not scan. Troubleshooting Assistant insists an error occurred during installation of device. It also says Epson Perfection V500 Photo does not pass...
Try shutting down your computer and then unplug from the power source. Wait a minute then plug it back in and turn on the computer.
Accept the driver installation even though it does not pass Windows Logo testing. Just accept it and continue with the installation.
1helpful
Need an Epson Perfection V500 Photo Scanner USER GUIDE....did not get one w/ purchase of the scanner. Thanks!
You can download a User Manual from the following location by clicking on the blue underlined link: Download Now
You will have to answer 4 simple questions about your printer and you will be able to download the manual for free!
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Kind regards,
BearWeb
1helpful
My Epson perfection 3490 photo scanner doesn't work on leopard. It worked fine on tiger. Do I need to download new software? The CD that came with my scanner says it is for Mac 10.2 to 10.4.
I googled Epson support and found the answer. Here it is:
Macintosh Leopard Support Contact Supportrightmenudottedline.gif apple_leopard_logo.jpg
Welcome to Macintosh OS X 10.5 Leopard support for Epson products. Here you can find out how to get drivers and other Epson software for your Epson product that work with Macintosh OS X 10.5.
Check your Epson product CD to see if it already contains Macintosh OS X 10.5 drivers. If the CD indicates support for Macintosh OS X 10.5, follow the instructions that came with your Epson product to install your drivers and other software.
If your CD does not list OS X 10.5 Leopard, follow the Step-by-Step Instructions below.
View our Macintosh OS X 10.5 Leopard FAQs.
4helpful
2answers
WANT TO DOWNLOAD A USER MANUAL FOR THE EPSON V500 SCANNER
Epson Perfection V500 installed. My computer recognizes it and diagnostic note says all okay. B ut when I turn on the power of the scanner, the grren light comes on in the front for about 15-20 seconds and then the scanner makes a loud grating noise and the green light turns orange and keeps flashing. No scan is attempted. TGhe noise sounds like something that should be moving can get started -- but nothing moves when you look at it. Should I take it back where I bought it?
2answers
By using the epson v500 photo I get the following massage: "Please remove the document mat and/or close the document cover" Off course I remove the mat and de document cover is close. I send the scanner to...
Possible driver issue. You have to reload the twain driver.
To uninstall the twain driver, please follow the ff instructions:
- Trash epson scan and epson scanner monitor from the harddrive
- Go to the library, then application support. Trash epson scanner module.
- Go to the library again, then image capture. Trash twain data sources.
- Go to the hd. Click on users. Click on the name of your computer. Click on library, then preferences, then epson. Trash epson scan.
Empty the trash and restart your mac.
When your mac is fully back on. Go to http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88368&prodoid=63070478&BV_UseBVCookie=yes&infoType=Downloads&platform=Macintosh&x=23&y=13 and you are now ready to install the Scanner Driver and EPSON Scan Utility v3.27.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
