Question about Fisher Price Toys
I have a Starlight Papasan cradle swing that will not swing. Is there a separate motor that controls the swing. I got it running for a while and then when it put the cradel back on with some weights it wouldn't run. I took the cradle back off and started it again...ran very briefly then stopped
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: i would like the manual
You can get the manual on the link below. It is not yours. It is just like yours though diffrent name.
http://service.mattel.com/us/product_detail.asp?id=K7924&Ntt=K7924&Pn=1&Brand=Fisher-Price+Babygear&Cat=Swings
Good Luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 26, 2010
Swing stopped working
Had the exact same issue, so I called FP. I had already taken the motor housing off to see if it was something obvious, like a loose connection or broken part. I didn't see anything wrong so I just cleaned it up and put it back together. When I called they offered to sell me a new motor for around $80. Then the lady I was speaking to (who was typing as we talked) said "hey, wait, there's a note in here about this issue..." She said to do what I had done, lightly clean it out with something like a keyboard cleaner, then using the plug (not batteries) set the speed to two/center. It somehow resets it.
That worked for me, and it was free. If that doesn't work then yes, you can get a motor directly from FP. Call the customer service number listed on the back of your manual, if you have it, or 800-432-5437. You'll need to have it nearby so you can give them the model number and year that is listed on the back of the motor housing (open the battery compartment if it isn't on the outside).
You can also get motors online, especially ebay, from any of the papasan swings FP makes. I love this swing so much that I think it's worth it. I've used it for four years now and plan to use it in the future.
Aug 01, 2012 | Fisher Price Starlight Papasan Cradle...
I need a new worm gear for my fisher price starlight papasan cradle swing.
I found a set of worm gears that has 2 of the gears you need.
Google search, worm gear svm-103. It is a packet with a lot of worm gears but the 2 big ones work perfectly.
Jul 05, 2012 | Fisher Price Starlight Papasan Cradle...
We closed up the swing for storage now we need to use it and the seat is wobbly any ideas where to tighten screws?
The main ones to tighten are the ones on the legs that you can see. What makes it really wobbly are the legs not being balanced or spaced apart wide enough. They should be extended out enough for them to be resting on the side of the top where they enter the motor housing, and the feet should be relatively flat on the floor. Push them out (don't force them of course) then use your foot to nudge them out until they're stable enough for your needs. I found it also helps to set this up on a carpet instead of bare wood floor. The swinging motion can sometimes rock the legs up/out a little and make it look unstable.
Aug 25, 2011 | Fisher Price Starlight Papasan Cradle...
My Starlight papasan craddle swing clicks loudly and the gears seemingly miss causing it to not swing properly whenever I put my baby in it (he only weighs 8 pounds). When there is no weight in it, it...
Make sure the legs are pulled out all of the way by pulling the legs outward. Make sure the buttons snap into the notches in the motorized frame. Also check to be sure the legs are locked into position by pushing the legs inward. The legs should not move. Also if you can adjust the swing from side to side make sure it is locked in place. That should fix it.
Jul 19, 2011 | Fisher Price Starlight Papasan Cradle...
I lost my fisher price papasan sing instrustions manual. is there an online manual?
There are numerous swings. Below is the page with them listed:
Fisher Price Papasan Swings
Click on the one that you have for the instruction sheet.
Thanks for using Fixya.
Apr 22, 2011 | Fisher Price Toys
Hi there, how do i adjust the chair on the fisher price starlight papasan swing? It is laying pretty low and i want to adjust it for the baby to sit more upright
If you haven't already figured this out, there are two pressure things on the underside of the swing. Just sit to the side or back of it to see them, push them both in, and tip it into the position you want. The upright position isn't upright like a chair, it's still a little reclined, so if you need a boost just slip a rolled up blanket in where you need it.
Apr 03, 2011 | Fisher Price Starlight Papasan Cradle...
Hi, I have a fisher price Papasan Cradle Swing. even though the mobile is working, the motor stopped working[its not swinging]. Is there any way i can get it repaired? my 9 month daughter finds hard time...
You can purchase replacement motors from Mattel (Fisher Price's parent company).
It will be one of the following 3 products, just pick the one that matches what you have now:
https://store.mattel.com/ItemDetail.aspx?cat=140&item=58050
https://store.mattel.com/ItemDetail.aspx?cat=140&item=59702
https://store.mattel.com/ItemDetail.aspx?cat=140&item=58374
Mar 10, 2011 | Fisher Price Ocean Wonders Cradle Swing
I would like the manual instructions for the fisher price nature's touch papasan cradle swing
Oct 26, 2010 | Toys
Toys Logo
70 people viewed this question
Top Fisher Price Toys Experts
Marvin
Marvin
NOEL
NOEL
yobo007
yobo007
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
