SOURCE: Message - eject cassette
I have exactly the same problem, please tell me if you have managed to resolve this and how. Thanks Jon
SOURCE: My ZR30mc video recorder will not eject cassette
Take the side panel off to see whether the tape is damaged and will not retreat into the cassette ( this will prevent ejection ). Remove old damaged cassette and insert new one. If the unit chews the new cassette camera should go in for VTR service.
SOURCE: cassette loading error 31:23
I have had this same problem several times. In all cases the problem has been a tape that has been run at the very end of it's lenght and it is too tighten. I loose the tape manually just a bit and it helps. Just be careful not to leave the tape too loose.
For loosing the tape you have to push the lock button with e.g. a pen and while doing that just take the tape out just a bit. Tape should be left at the level it was. It must not look like a loosen tape. If you get it out too much, just roll it back by twisting the reel again while pushing the lock button down.
To be able to loose the tape you of course need to open the protective lid first. For this there is a separate lock switch at the side of the cassette.
SOURCE: will not accept cassette - keeps responding "eject cassette"
Had the same problem and took the battery out of the camera to reset. Worked fine after that.
SOURCE: Can not load any cassette even empty cassette holder can not be closed.
I had the same problem and solved it by removing the battery to allow the camera to reset. Worked fine after that.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
