From the kodak website:
Error "System status failed" (3807)
How do I resolve the error message "System status failed" (error code 3807)?
To resolve the error message "System status failed" (error code 3807):
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
Open the printer access door.
Remove and install the printhead two times.
Close the printer access door.
Wait until the printer is ready to use.
If the error is resolved, upgrade your printer's firmware.
If the error is not resolved, contact kodak.
Hope this helps
Hi, still showing this error. call Printer Experts -
877-690-9305
they will fix your issue free of cost.
For more help visit https://cbrtechsolutions.net
it means System status failed" (3807)
http://support.en.kodak.com/app/answers/detail/a_id/1249/~/error%3A-system-status-failed-(3807)/selected/true
SOURCE: printhead system error code 3807
Your printerhead is loose or has gone corrupt. Try reseating it and calibarate the printer. If does not resolve you issue, your printhead needs replacing.
NOTE: If printhead already replace, you need a replacement printer.
thanks
SOURCE: My printer ESP5 shows an Error code 3807. I do
Maybe the printhead is not working properly. call Kodak and they will going to replace tht printhead. Thanks
Error code 3807
