Remote Start System  Logo
Posted on Jan 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I recently had my car battery diconnected and my remote start doesnt work anymore. How do I re-program this function?
Anonymous
Level 3:
Director Badge:
Uploaded 100 video answers.
  • Master 1,751 Answers
  • Posted on Jan 09, 2011
Anonymous
Master
Level 3:
Director Badge:
Answers
1751
Questions
Helped
358840
Points
4943
Hi
this fuction cun only be set
from the shop you got your car
Autostart after battery disconnected blue light
do any other functions of the fob work?-Denny
Remote start wont start the car
try hitting function twice so its at level 2 code and hit the unlock button, that sends it into remote valet mode. if that isnt it make sure the valet toggle switch is on and connected
I recently changed the batteries in my keyless remote. Now it is not working. How do I re-program the remote?
take your remote to a dealer and have them test it. the car's receiver is set to match the remote, not vice versa. often corroded and dirty switch contacts inside the remote keep it from functioning, even with new batteries. you may need a replacement remote, the are about 10 bucks used on eBay.
I have a older unit it has keyless entry bought in the 90s it quit working. untill recently car started by it self probly from another remote interferance how do i diagnose it?
reprogram the remote to your car 4 times, this way any other remotes programmed to your car won't work anymore, because the unit only holds 4 frequency's
4helpful
2001 ml320, remotes quit working. new batteries,
Synchronization
Turn ignition switch to position II. Turn ignition switch to position 0 and remove key. Within 1 minute: Press and hold key lock button. Press unlock button 5 times. Remote control should now operate system. If not: Repeat procedure.
Programming
When
Key remote control added or replaced. System malfunction.
How
Keys can only be programmed using diagnostic equipment
2answers
6helpful
3answers
My key fob remote will not unlock car doors but will start car
Here you go.If you can't read it I can email it to you.
2helpful
MWD2205 remote stopped working for DVD functions
not sure but it sounds like you need to push the dvd button itself before dvd functions will work-it's to the left of the pause button. same thing happened to me and when i try that it works. remote seems to default to vcr i guess ....
Programing remote
is the remote still working on the vcr??? if so then simply take out the batteries for a few minutes and reinstall and reprogram the remote for the proper tv. if it doesnt work then the remote is bad and a new one avail on line or at universal one can be used The oart # for the Sylvania is N9211UD
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
ZJ Limited
ZJ Limited
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
