Re: Dssusb.dll and dssusb1.dll error on software load on...
Copy both dssusb.dll and dssusb1.dll to C:\Program Files (x86)\Olympus\DSSPlayer or where ever the program has installed. Both these files are on the installarion disk.
run.dll is a DATA LINK LIBRARY FILE if it is sikped in installing windows {or} other any software ,malware,adware virus problem you can fix it by using DLL suite { the dll suite download and install it will have a lot of serials keys in serial.ws.com } you will enjoy the features of windows
avgxch32.dll is an AVG anti virus dll. You will need to upgrade AVG to the most current version or change it out for another Anti-Virus program.
If you have the most current version, uninstall it and reinstall a new copy.
The first thing you must do is to identify the specific rundll process. This is not a difficult task; there is a vast online process library in which you can evaluate the validity of the process that is running. When the error dialog box opens make not of the process name. For example if the dialog pops up and shows you the dll error:
Error loading C:WINDOWS\ system32\ usvdgpo.dll Visit www.processlibrary.com. Copy and Paste the dll or simply type it into the search box. The results will indicate that the program is a part of trojan spyware.
STEP 2: STOP THE PROCESS
Often you can locate the Run Dll in the exe services. You can open up your services configuration by following instructions below: 1. Open your Start menu. 2. Click Run 3. In the command screen type:services.msc 4. This will bring up the Services Management window. If you drag the mouse to one of the services. It will give you a detailed explanation of the service in question. By right clicking the individual service. 5.Stop the "dll"service immediately. STEP 3: LOCATE AND DELETE
You will have to open your Windows Registry File System. This is an extremely delicate process. You may want to use a good registry cleanerThis will often fix the dll error in question, eliminate other errors and also speed up your computer. The registry key: HKEY_LOCAL_MACHINE> SOFTWARE\ Microsoft\ Windows\ CurrentVersion\ RUN
This action will help you speed up your applications load times considerable. Here is how:
1. Click Start 2. Click Run 3. Type regedit 4. Find this registry key: HKEY_LOCAL_MACHINE> SOFTWARE\ Microsoft\ Windows\ CurrentVersion\ RUN
5. In the right section click:"rusvdgpo" = "%System%undll32.exe %System%usvdgpo.dll, [RANDOM LETTERS]" 6. Delete the value and Restart.
When I start My PC the RUNDLL error occursError loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found. Solve my this problem as soon as possible.
Try running RUN and type regsvr32.exe /i shell32.dll. Thisactually fixes the shell32.dll and installs it again.
RegSvr32.exe has the following command-line options:
Regsvr32 [/u] [/n] [/i[:cmdline]] dllname
/u - Unregister server /i - Call DllInstall passing it optional [cmdline] (/i /u calls dll uninstall) /n - do not call DllRegisterServer (must be used with /i) /s Silent (added with Windows XP and Windows Vista)
