Dryers Logo
Posted on Jan 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My whirlpool cabrio dryer start button is flashing and when i push it nothing happens. the front door is closed and light is off. how can I trouble shoot this myself. Joe
  • m sami Apr 15, 2023
    Hi Joe! Here are a few things you can try to troubleshoot the issue:
    Check the power supply: Make sure the dryer is properly plugged into a working outlet and that the circuit breaker hasn't tripped. If the dryer isn't getting power, the start button won't work.
    Check the door switch: Even though the door is closed, the door switch might be malfunctioning and not registering that the door is closed. Try opening and closing the door a few times to see if that helps. If it doesn't, you might need to replace the door switch.
    Check the thermal fuse: If the dryer overheats, the thermal fuse will blow and the dryer won't start. You can check the thermal fuse with a multimeter to see if it's working properly.
    Check the control board: If none of the above solutions work, the control board might be malfunctioning. Unfortunately, testing and replacing the control board can be tricky and might require a professional.
    Click here if you want to know complete detail about Why is Your Whirlpool Cabrio Dryer Start Button Flashing?
Tim Whalen
Level 3:
  • Master 3,076 Answers
  • Posted on Jan 09, 2011
Tim Whalen
Master
Level 3:
Answers
3076
Questions
0
Helped
823564
Points
9577
Http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Melanie F Crawford
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 31, 2016
Melanie F Crawford
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3571
Points
Just took my Whirlpool Dryer out of the box. Plugged it in and all the lights are flashing and Only goes off if I unplug it. :(
  • Tim Whalen Dec 31, 2016
    You will have to run the tests in the manual.It should tell you what to do if the diagnostic mode can not be entered. If you remove the top the tech manual should be under there.There are screws along the back edge of the top to remove it.You need to put the machine into its diagnostic mode.It should give a code as to what is the problem.The tech manual will tell you how to do this. Hope this helped..Happy New Years Tim
Turn on power, the lights come on but when you press start nothing happens just a click sound.
Click sound at power button and start button should get it going. If not then Dryer drum is not turning.
Dryer has power - we can hear the timer ticking and the light comes on when the door is opened, but when we push the start button nothing happens model # leq9558ko 8 yrs old electric
does the light close when the door is closed??? poosible that the door switch has gone bad. or a bad thermal fuse behind the unit is also a common culprit of this.. its a white thermostat on back of unit behind the panel (-----------------------) approx this long ad white,,
Whirlpool dryer push start button and nothing happens
check the switch that detects that the door is closed,it can break even though the door is closed it doesnt start
7helpful
2answers
Cabrio washer want start.
leave the door open and try it again if it does the same thing as before the door lock has gone
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 • Dryers
1helpful
When I push and hold start nothing happens
can also be an issue with t door lock/latch assy, if it doeesnt recognize the door closed it wont start
Top Dryers Experts
john h
