You can download the driver from this site
http://go4download.com/hp-pavilion-dv5-driver
HP Pavilion dv2000 laptop Audio, Lan, Chipset Drivers For Win XP
Can have it here
http://en.kioskea.net/forum/affich-17903-hp-pavilion-dv2000-drivers
SOURCE: hoow to install a dv2000 hp pavilion dvd rw drive (internal)
Remove the Phillips PM2.5x7.0 screw (1) that secures the optical drive to the computer
Insert a thin tool, such as a paper clip, into the media tray release hole (2). (The optical drive media tray release from the optical drive)
Use the media tray frame to slide the optical drive (3) to the left.
Remove the optical drive.
You can download the complete manual here:
http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
SOURCE: XP on HP Pavilion dv2000
First of all, this Notebook is installed with SATA Hard Drive and the drivers for the SATA Hard Drive will not be available with retail versions of Windows XP by default.
I recommend you to try using different OEM versions of XP to install in your Notebook which should work.
Since the Notebook is preinstalled with Windows Vista, the XP Drivers for this Notebook are not directly available from HP.
I had searched some for you which should work.
Download the Drivers one after the other and save them with the name along with the Softpaq Number like the example given below :
Microsoft UAA_33566.exe
So that it will be easier for you to save them and identify.
Save the drivers in one location in the Notebook and double click them once the download is completed.
Make sure that you install the Microsoft UAA Drivers before installing the Audio or Modem Drivers.
Make sure that you install them in the same order I had provided them below :
You need to download the Intel Chipset Drivers for your Notebook from the link below :
http://downloadmirror.intel.com/16023/a08/infinst_autol.exe
Microsoft Universal Audio Architecture(UAA) drivers for High Definition audio :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33566.exe
Conexant High Definition(HD) audio :
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
As the Notebook is installed with Intel graphic Card, you need to download the Drivers for the same from the link below :
http://downloadmirror.intel.com/16944/a08/win2k_xp14363.exe
Download the Ricoh 5-in-one Card Reader Driver from the link below :
ftp://ftp.hp.com/pub/softpaq/sp37501-38000/sp37712.exe
Download Intel PRO/Wireless Drivers from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34489.exe
As I am not sure whether your Notebook is installed with Intel or Realtek Ethernet card, I am providing both the drivers:
Intel Ethernet Drivers :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33574.exe
Realtek Ethernet Drivers :
http://drivers.softpedia.com/progDownload/Realtek-RTLRTLRTLRTL-Driver--WHQL-Download-33009.html
You can also try downloading the Marvel Youcon Ethernet Drivers if any of the above provided drivers did not work :
ftp://ftp.hp.com/pub/softlib/software10/COL24713/gs-63707-1/Marvell_Yukon_LAN_Driver_6.36.0.0.exe
Downlaod Conexant HDAUDIO Soft Data Fax Modem drivers from the below weblink :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33890.exe
Download the HP Quick Launch Buttons drives from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp38501-39000/sp38688.exe
Download the HP Pavilion Webcam Driver from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33544.exe
Download the Alps Touchpad driver from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33751.exe
Finger Print Reader Driver :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32869.exe
Hope these helps...
