Of course you can.
To play MKV on Samsung Smart TV, you firstly need to transfer MKV files to Samsung Smart TV with a USB portable device. Just stick the USB device with the MKV files inside to the Samsung Smart TV, and then you could play back MKV files in USB on Samsung Smart TV.
If you still can't play MKV files, then it is a matter of file format. You need to convert the file format. After the conversion is over, you can freely enjoy the converted MKV movies on your Samsung TV thru USB, media server like Plex, Jellyfin, Emby, DLNA, etc. without any trouble.
Here is the guide: How to Play MKV Files on Samsung Smart TV?
MKV is really one of Samsung TV compatible video formats. If your Samsung TV won't play MKV, that is because MKV is a container format, which is a kind of Matroska media files while Matroska is a new multimedia package format, also known as multi-media containers. You can check on this article for some solutions:
Usuallys Samsung PN50A650 does play MKV files via USB drive.
However, MKV is a container video format which may contain video or audio codec which are not supported by Samsung. Therefore, sometimes we still cannot play MKV on Samsung PN50A650.
To solve this can't play MKV on Samsung issue, you may follow this article at http://www.idealshare.net/video-converter/samsung-tv-mkv.html
Samsung TV Wont Play MKV Solution Convert MKV to Samsung TV
SOURCE: Help Playing .mkv File on Samsung UN55B6000VF
Yes, get a UBS drive. or wireless adapter.
Testimonial: "Thanks so much for your help... I will try that!"
SOURCE: LG 32LH40 Firmware Update. Has anybody found one?
At the following website there are lg tv firmware updates but the 32lh40 is not listed. Likely you will need to contact lg support. I was looking for one just for general maintenance on the same model.
http://us.lgservice.com/vchip_html/V-chip_upgrade_for_your_set.html
