Columbia Telecommunications Group FRS22-SPR (22 Channels) 2-Way Radio Logo
Posted on Jan 08, 2011
Have pair of FRS14ND radios, with charger. One battery pack has quit, so other must be about to. Tried switching remaining pack between radios & both work, so it's not radio. Can't get AAA alkaline batteries to work in either, despite being careful to install according to diagram in compartment. Where can I buy a replacement SD30AAA4Z battery pack & what's estimated cost?
Possumn
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Jan 20, 2011
Possumn
Contributor
Level 1:
New Friend:
Answers
8
Questions
Helped
3095
Points
14
Similar problem, solved when dirty contacts were cleaned, look for some corrosion on either the battery pack or in the radio battery holder. Use very fine grit sand paper.
also check to see if a tab on the battery holder contact is bent inward (radio dropped perhaps)
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
Cobra microtalk will not charge
this is the sign of a damaged or dead battery pack. they can be rebuilt at Batteries Plus or replaced. I would also try alkaline batteries in the radio before spending money on new battery packs. Most rechargeable battery packs must be kept charged regularly, and should be fully discharged before recharging, or they will be damaged and end up with a limited lifespan. IF you are handy with a multimeter you can check to see that the charger is putting voltage out by placing the probes on the contacts while it is plugged in. especially if the cord is twisted or looks stretched, but generally it is the battery not the charger.
I have a cobra microtalk that is on and the batteries are charged, but when I click on the call button or to radio someone else....it does not patch through. The radio also does not receive any calls nor...
Exchange batteries with the working radio... does the problem radio work again?
Many times battery connections get quite dirty and require cleaning...
Also inside tiny cheap wires pull lose OR battery charger jacks have bad connections so that's why we tried the battery swap first...
The POWER/VOLUME control sees LOTS of action too and often the power switch fails there.
You MAY hunt on eBay for a used set and then you will have THREE working radios and extra batteries and chargers too!
HECK just found a PAIR NEW in the package for about $22.50 ~ DEAL!
I need replacement batteries for a Columbia FRS14ND model 2 way radio. Which type of battery and where can I get them?
your local watch repair man can replace the battery or you can go to bestbuy.com or radioshack.com and identify the battery there by entering the watch makers information.
1helpful
I have some frs14nd radios and am looking for rechargable batteries for them. Contacted the company several years aga and they said they would send me some but never heard back. can you help, thanks randy
I couldn't locate a battery pack specifically marketed for the FRS14ND, but information I did find indicates that your radios will operate on standard AAA batteries.
Bill B
3helpful
Low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
FRS-14ND 2 way radio
Hello you can recharge the batteries only if the bateries you are using are rechargables, this could be Bat recharg. 2AA or 3AA or a pack.
Top Columbia Telecommunications Group Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Columbia Telecommunications Group Radio Communication Expert? Answer questions, earn points and help others
