Posted on Jul 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset error code E000 on IR2000
Power went off momentarily. Now Canon IR 2000 has error E000.
How do I reset this?
  • 2 more comments
  • Anonymous Aug 05, 2008
    I have a System error code E0000 on my copier. How do I correct this problem?
  • Anonymous Nov 25, 2008
    i cant select yes after i select 4 and press ok, please help
  • Anonymous Dec 11, 2008
    I want to know what causes error E007 IFthe fuser sleeve is not shifted to the side.
  • jawid2008 Jan 19, 2009
    SYSTEM ERROR
    E000
Anonymous
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Jul 12, 2008
Anonymous
Contributor
Level 1:
New Friend:
Answers
8
Questions
Helped
12110
Points
29
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
  • Anonymous Jul 25, 2012
    I am so happy my problem was solved when I used the procidure
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 12, 2008
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
10659
Points
5
A printer shows a system error E000. how do i fix this?
Anonymous
Level 2:
New Friend:
  • Expert 70 Answers
  • Posted on Nov 24, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
70
Questions
0
Helped
98393
Points
117
Reset procedure for more than 12 Canon printers have been described here:
Canon Error Reset
michael hiwot
Level 1:
New Friend:
  • Posted on Aug 12, 2016
michael hiwot
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
10659
Points
Ermyas Aklilu
Level 1:
New Friend:
  • Posted on May 11, 2016
Ermyas Aklilu
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
10659
Points
Canon IR 2202
Error E000-0000
Error defnition: fuser error occur on power fluctuation
solution: press reset button(yellow equal signed) and back buttun plus user mode button(man with asterisk icon)
I have canon ir2000 photocopier machine and i t is showing e354
Canon IR 2000 copier is showing System Error E000
From my searches online the first course of action seems to be resetting the printer in service mode.
I attempted to clear it in service mode:
1. Press ADDITIONAL FUNCTIONS, #
2. Go to #7 Printer and press OK
3. Go to #4 Printer Reset and press OK
4. Yes = ( > )
However, when I press the yes (>) nothing happens.
Does anyone know why this is not working?
Sir, i have question- error code E000 IN CANON iR 1600 i have copy macheine i wsh you help me
E000 : fusing problem ,check the thermistor, therm fuse and heater lamp then try to reset it by reset error code.
3helpful
My canon ir2000 copier says: System Error E000!!! what can i do for this kind of error. my exact copier model is Canon IR2000. sorry for product identification i didn't get my model from the list thus why...
That means that you have fixing error.Try next:
press MENU and #, with cursors go to clear, press ok, select err or all and ok.
If the problem was only fluctuaction in temperature the machine would work normally.
If not call service, because you have problem with heating lamp, or thermistors, or...
hope that helped
Refretion key of canan IR2000 copier
do you have to change the film unit and you can't to reset this code.
3helpful
System error E000 in conon ir2000
Sir,
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Thanks
Good Luck
4helpful
2answers
2answers
2helpful
Ir 2000, system error E000
The main thermistor reading does not reach 40°C 14 sec after the fixing
heater goes ON. (fixing low temperature error)
If E000 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Entering service mode: press "aditional function" and after "#(ID)"
Thanks for the info on canon IR2000 fuser code reset. Do You Know if This procedure works on all IR models? And Thanks again for your prompt reply. Ernie
posted by ernie52 on Jul 14, 2008
Yes it will works on all IR models! I try it many times for all my customer here in Saudi Arabia and it works all the time!
Christopher
21helpful
4answers
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
old marine
old marine
ZJ Limited
ZJ Limited
