The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter. I offer free advice bcuz God is so good!
Oven clicks as if it is relighting almost constantly.
Old electric range ovens use a coil heating element called a resistive coil.
This is nothing more than an electrical wire encased in a sheath. They have flat black coils over rounded burner drip bowls that catch your drips and spills.
The newer glass-ceramic cook top style element produces heat that radiates through the glass top to the cookware above.
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system.
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
One of the switches is stuck,causing circuit to 'think' that you're trying to light a burner. Give each control knob a good 'tap' with the back of a screw driver.If that doesn't free it up, we will have to find the stuck switch
1 of 2 things will normally happen and most of the time both things will break. You have two main componets that will wear out 1)your igniter 2)the gas burner tube. Usually what will happen is the gas burner tube allows gas to come out of 3 very small holes-over time and with help from grease, the 3 small holes will turn into a large hole and will allow too much gas to come out and it will destroy your igniter also. Luckly RepairClinic.com sells both pieces in a kit. You can check you igniter with multimeter for continuity (if it is broke-safety kicks in and wont allow gas to work).
Many gas stoves are designed to switch all top igniters on at the same time.. that may be normal for yours.. many will continue to cycle several times and then stop.. You may not have a problem..
I just installed one in my house. I found that when you start the lower (gas) oven you need to turn the dial all the way on to 500*, push the knob in (you should hear the igniters clicking), then even when you see flames coming out of the burner, continue the ignition for 10 to 15 seconds. It should continue to stay lit thereafter.
We had the same problem on a Thermador cooktop with the same RI-302 ignitor. Turns out it was one of the switches that sits on top of the gas valves. These switches cause the ignotor to fire when the valve is turned. In our case, one of the switches had malfunctioned and was "always on" causing the ignitor to continuously fire.
