Hi Fran:
Most shower faucets now are equipped with flow restrictors. It is possible with some units to remove the flow restrictor plate from the shower nozzle. It has to be dis-assembled to do that.
Regarding the lack of hot water, that would usually be a different problem and will be related to the hot water source.
Hope this helps.
These types faucets have a what is called an anti scald valve build into them, it is required by law, it is either defective or out of adjustment, contact a local hardware store for more detailed info.
Many single-handle shower mixers have a hot limit, usually limiting the throw of the handle. You could go to the mfg's website (www.deltafaucet.com) & find instructions for adjusting it. Or, if you're handy, you could take off the handle & have a look; it shouldn't be too hard to see what's stopping the handle from turning more towards the hot side. Make changes in small increments & remember where you started.
the pressure in pipes has to do with the volume. The bigger the pipe the better the pressure. Take the time to trace out your hot water line and see if you can find any old galvonized pipe, thats usually the problem in most cases. galvonized pipe over time will rust and corrode causing restriction in the water line. replacing it with 1/2" copper should solve the problem.
I just spent a week wrestling with a similar problem, and I'm posting in an attempt to save someone else an ulcer. Using a Colony single-handle valve, the temperature got so we couldn't control it. Either all hot or all cold. I called A.S. and they sent a new pressure balancing cartridge and new valve cartridge. Replaced both and then there was no water at all coming out of the shower head. Tried every possible combination of old and new parts, flushed pipes, etc. Finally took the shower head off and found it completely clogged with debris. It was a mix of sediment and the white grease that was in the new cartridges, which must have been displaced when I started messing with it. And it clogged it all at once (no flow problems before all of this). Works fine now!
Remove the handle,and all the trim rings,and the cartridge cover. take a flat head screwdriver and use it to lift up the red ring behind everything, this is the hot limit safety stop, this just stops the handle from turning to full hot.
Once you have the red ring lifted up, notice the numbers and the pointer on the ring, numbers are on the fixture,
O= hottest 7=cold
See what the ring pointer is set to now, and move it half, before you put this back together, just set the handle on the unit and run the water to see if its to hot or not enough. Once you have found what is the best setting, then replace all covers and trim, handle.
