GE Profile JGP636 Gas Cooktop Logo
Posted on Jan 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a GE Profile JGP990 gas cooktop. The igniters are generating a regular spark and once the gas flows it lights immediately but often when I turn it on cold there is a delay of 20-30 seconds before I hear the gas flow. This happens especially when the stove is cool. After one burner has been running a while the other burners will light within a second or two. Any ideas?
Anonymous
Level 3:
  • GE Master 43,501 Answers
  • Posted on Jan 08, 2011
Anonymous
GE Master
Level 3:
Answers
43501
Questions
0
Helped
10835461
Points
101584
Your problem could be or probably is with the regulator...the regulator is sticking......
Propane, LP, or Natural Gas Regulator Problems
heatman101
Can a GE profile black 4 burner with down draft gas cook top be converted to propane gas? How?
Hi and welcome to FixYa, I am Kelly
Everything I am reading says this unit comes with an LPG conversion Kit. It may have been removed by the detailer / retailer that you purchased it from (when ever that was.)
The 0.0354 orfices are supposed to be in the front of the inside of the cooktop and are labeled LP.
It is a matter of removing the 4 Natural Gas orifices and installing the LP orfices and then adjusting the air-flow of the grill burner Air Shutters as shown in the manual on page 32.
The center nut has to be removed from the top of the internal gas regulator and the mini post / plunger inverted and then the nut is reinstalled.
Just note that any conversions are supposed to performed by a qualified gas technician as stated by the WARNING in the manual on page 30.
The manual is here:
http://www.hammerwall.com/tempmanuals/L0603449.pdf
The step by step instructions are in the product user guide on page 30
or you can go to this link and click on info and guides:
http://www.ajmadison.com/cgi-bin/ajmadison/JGP990.html
then download the use and care guide.
Thanks for choosing FixYa,
Kelly
Cooktop model JPG933BEC2BB right front igniter quit working
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Ignition stoped working on my ge profile gas cooltop
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Profile JGP636 Gas Cooktop: my ignition for the gas cooktop is not clicking...
heatman101
1helpful
GE Profile nat gas cooktop, Model No JGP636BEV3BB won't ignite
If you can hear the clicking sound but are not getting a spark then there is probably a short in the ignition system. Check for any loose wires on the ignition system. Make sure all the wires are properly seated. Make sure the spark module is properly grounded. As far as testing the spark module it should be generating a spark of course. The problem is that the average voltage for the spark module is 15,000 VDC so actual testing of that voltage can be difficult. Is the spark erratic?(should spark evenly). An erratic spark timing is a sign of a bad spark module. Is the spark slow? Check the polarity of the electrical plug. If it is clicking evenly then it is probably arcing somewhere inside the cooktop and you just need to find out where. Also be aware that if you get water into the cooktop that can cause possible grounding of the spark module or ignition system.
Ignitors are igniting on their own
they are not lighting they are sparking on there own right? No actual flame? if they are sparking on there own you need a new spark module.
May 30, 2009 • GE Cooktops
Top GE Cooktops Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
