Computers & Internet Logo
Posted on Jun 19, 2017
Hello, Putting my Microsoft ® 2.4
5 Related Answers
hebiz mohammed ali
  • 58 Answers
  • Posted on Apr 04, 2009
SOURCE: How do I set up a microsoft wireless desktop elite keyboard
no need to buy go to this page
http://www.microsoft.com/hardware/download/DownloadResult.aspx?category=MK&type=Keyboard&name=pk_kefbt&os=XPSP2&lang=en
feed back plz
Anonymous
  • 94 Answers
  • Posted on Mar 01, 2010
SOURCE: I have a new computer with Windows 7 operating
Yes there is ofcourse downloads for your keyboard and mouse
It is avail at following microsoft's site
Just go to the site and selcet desired hardware(Mouse or keyboard)
and select the Operating system and its version
and click go
it will show you the available downloads for your products and
mow select it ,click download
Hope this will solve your problem
Testimonial: "I asked the question and got an answer that was exactly correct. My problem was corrected in just a few clicks of the mouse. Thanks!"
Computer Links
  • 2386 Answers
  • Posted on Dec 09, 2010
SOURCE: I have a Microsoft wireless
The symptoms shows that the receiver of the mouse and keyboard has gone faulty, need to be replaced or repair.
Good Luck
Anonymous
  • Posted on Apr 29, 2011
SOURCE: need new USB 2.4 GHz transceiver for my wireless keyboard
I found a 2.4ghz tranceiver that I have no use for. Am broke but would take bottom dollar for it...
Anonymous
  • Posted on May 03, 2011
SOURCE: I have a Microsoft wireless desktop 3000 v2.0
Call Microsoft parts replacement 800-360-7561 and tell them what happened and they will help you. You will need to get the Product ID from the back of the keyboard: 01036-545-7152051-01006. It is not possible to get the USB transceiver separately.
2answers
Where is the pairing button on Microsoft wireless keyboard 6000 v3.0 or does it need a USB plug
The Microsoft Wireless Keyboard 6000 v3.0 comes with a USB transceiver that you need to plug into your computer's USB port to connect the keyboard to your computer. The keyboard and the transceiver are pre-paired from the factory, so you don't need to pair them again unless you replace the transceiver or the keyboard. If you do need to pair the keyboard and the transceiver again, you can follow these steps: 1. Insert the USB transceiver into your computer's USB port. 2. Turn on the keyboard. 3. Press and hold the "Connect" button on the underside of the keyboard for a few seconds until the green light on the transceiver starts flashing. 4. Press the "Connect" button on the USB transceiver. 5. The green light on the transceiver should stop flashing and stay on, indicating that the keyboard and the transceiver are now paired. Note that there is no separate pairing button on the Microsoft Wireless Keyboard 6000 v3.0 itself. hope it would be of use to you
I have an emachines El-1352G-41W What are my options to expand this system into "CAD" system?
If you mean AutoCAD then you need the following:
You can get more information at:
http://usa.autodesk.com/autocad/system-requirements/
For 32-Bit AutoCAD 2012
  • Microsoft® Windows® 7 Enterprise, Ultimate, Professional, or Home Premium (compare Windows 7 versions); Microsoft® Windows Vista® Enterprise, Business, Ultimate, or Home Premium (SP2 or later) (compare Windows Vista versions); or Microsoft® Windows® XP Professional or Home edition (SP3 or later)
  • For Windows Vista or Windows 7: Intel® Pentium® 4 or AMD Athlon® dual-core processor, 3.0 GHz or higher with SSE2 technology; for Windows XP: Intel Pentium 4 or AMD Athlon dual-core processor, 1.6 GHz or higher with SSE2 technology
  • 2 GB RAM
  • 2 GB free disk space for installation
  • 1,024 x 768 display resolution with true color
  • Microsoft® Internet Explorer® 7.0 or later
  • Install from download or DVD
Bluetooth device not working and not detected in device manager
Good day. In regards to your issue when it comes to your bluetooth device you can try the following steps. Usually these will resolve your issue
1. If your Bluetooth device uses batteries, make sure that your batteries are charged. 2. If your Bluetooth device uses a transceiver that connects to your computer through a USB port, try connecting the transceiver to another USB port on your computer. 3. If there are multiple Bluetooth devices connected to your computer, temporarily remove the devices that you are not troubleshooting. If there are additional USB devices, try removing any USB devices that you do not have to have installed during the troubleshooting process. If you h have multiple devices that are connected by using USB, this can interfere with a Bluetooth transceiver. 4. Verify that the Bluetooth device that you are troubleshooting is powered on and that it is enabled.
If these steps didn't resolve your concern, you can try to update your windows version like installing updates that can be found on the microsoft.com website or go to http://update.microsoft.com. You also have the option to contact HP for them to help you with issue but most probably they'll be charging you for this specific problem. Hope this information will be helpful in resolving your concern. Have a great day and thanks for using Fixya.
2helpful
I have a Microsoft wireless mouse that uses a 2.4 GHz USB style thumb stick transceiver to communicate w/my laptop. That transceiver is damaged & cuts in & out. My question is, can I buy a new 2.4...
Sorry! you can't. Because, although its 2.4Ghz, a special code is included in the signal so it won't mix up with any other wireless devices.
pls. vote for better service... Thank you
Pasos para instalacion de web camvx2000
Hola amigo primero que nada devemos saber que systema operativo usa tu computador Windows Xp Vista or Windows 7
Esta Web cam es configura automaticamente per piensa tambien en los requerimientos del su systema. aqui algunos tips.
Habla en espanol y solo pregunta ok
Techbelkin
System Requirements Operating System For Windows®-based PC
Requires a PC that meets the requirements for and has installed one of these operating systems
Processor Windows® 7
Mmimimum: Intel Pentium 4 (3 GhZ), 1 GB of RAM; recommended: Intel Pentium (Dual-Core 1.8 GHz), 2 GB of RAM, 1250 MB free Windows Vista®
Windows® XP with Service Pack 2 (SP2) or later
Other CD-ROM
USB 1.1 (2.0 recommended)
16-bit color depth or higher, 2 MB or higher video memory
Windows-compatible speakers or headphones Internet Broadband Internet access may be required for certain features. Local and/or long-distance telephone toll charges may apply.
Internet functions also require Internet Explorer® 6/7 for installation; 25 MB hard-drive space typically required.
On a Fujitsu fi-6230 I keep getting an error occured communicating with scanning device. please ensure that the scanning device is connected properly and try again.. i have to keep uninstalling and...
This a USB scanner and it supports the following OS's: Microsoft® Windows® 2000 Professional / Microsoft® XP (32 bit/64 bit) / Microsoft® Windows Server™ 2003 (32 bit/64 bit) / Microsoft® Windows Vista™ (32 bit/64 bit). IF, the usb cable is connected in the front usb connectors go ahead and plug it in the back usb ports since sometimes the front usb ports are either to slow or not connected. Additional, after pluging the the scanner on the back usb ports restart your computer and then proceed reinstalling the drivers for it.
2answers
Details of acer extensa 4620 laptop
Here's a link to the manual. All the details you could ever need.
http://www.marriage-4u.com/files/notebooks/ex_4620_4620z_4220_user_guide_eng.pdf
Need new USB 2.4 GHz transceiver for my wireless keyboard
2answers
Does my w3507 have an agp port
No it does not have an agp port. IT has a PCI Express Port for video cards. Its much better and faster.
Details on your machine and what it has can be found at this link. Hope it helps.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2912877&CatId=2643
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
