Operating instructios can be downloade here:
http://www.retrevo.com/s/Denon-CDR-W1500-CD-Players-review-manual/id/363ci860/t/1-2/
10 COPYING PROCEDURE
About copying
Copying can be performed easily from the set’s CD unit onto the CD-R unit.
There are two copying speeds (normal and high) and four copying modes.
• The mode switches as described below each time the normal speed copying button (NORMAL) or the high speed copying
button (HIGH) is pressed.
• The recording level is automatically set to the default value (0.0 dB).
• The repeat and random play modes are canceled when the copy mode is set.
• During normal speed copying you can listen to the sound as you copy.
• During high speed copying no sound is produced.
• No signals are output from the digital outputs during high speed copying.
• During copying, buttons other than the CD or CD-R stop buttons do not function.
• When CD TEXT compatible CDs are copied, the disc names and track names are also copied.
When copying, switch the relay mode to the normal or dual mode. Copying is not possible in the relay or mix mode.
For optimum recording, make sure there are no fingerprints, scratches or dust on the signal surface of the source side CD or
the CD-R/RW.
The auto track function is always activated in the copying mode. It is not possible to assign track numbers manually.
Disc dubbing: In this mode, entire CDs can be copied onto CD-R/RW.
(“All Tr Dubb” is displayed.)
Make CD: In this mode, entire CDs can be copied onto CD-R/RW then finalized automatically.
(“Make CD Dubb” is displayed.)
1TR dubbing: In this mode, single tracks on CDs can be copied.
(“1Tr Dubbing” is displayed.)
Scan REC dubbing: In this mode, the desired tracks can be selected from CDs and copied.
(“Scan Rec Dub” is displayed.)
The problem turned out to be I was not using Music CD's in the unit.
Never knew there was a difference.
I am trying to record a cd from a tape, which I have done many times on exactly the same kind of disk. Now it won't record. CONSUMER shows in the display window, which according to my instructions, means wrong type of disk. WHAT'S WRONG?? I've tried 3 different brands of cds and it does not work. Thanks. LC My recorder is a Classic CDR200.
I trying to record from a multi digital recording studio to my Classic CDR-200 and "Consumer" pop up every time and im not able to record.. if anyone can help me it would be appreciated..thx
