Epson Perfection 1670 Flatbed Scanner Logo
Constance Schmall Posted on Jan 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My scanner is not scanning the full slide - Epson Perfection 1670 Flatbed Scanner
Anonymous
Level 2:
  • Expert 61 Answers
  • Posted on Jan 08, 2011
Anonymous
Expert
Level 2:
Answers
61
Questions
Helped
12416
Points
186
Contact epson for this problem
7600i not scanning full slide?
It's possible that the scanner is not correctly detecting the slide frame size or that the slide is not positioned correctly on the scanner bed. Here are some things you can try to troubleshoot the issue:
  1. Check the slide holder: Make sure that the slide holder is properly aligned with the scanner bed and that it's not blocking the edges of the slide.
  2. Clean the scanner bed: Make sure that the scanner bed is clean and free of any dust or debris that might be interfering with the scanning process.
  3. Adjust the scanning settings: Try adjusting the scanning settings to ensure that the scanner is set to scan the full frame of the slide. Look for options such as "auto detect slide size" or "manual crop" to adjust the scanning area.
  4. Use a different scanning software: If the issue persists, try using a different scanning software to see if that resolves the problem.
  5. Check for firmware updates: Make sure that your scanner's firmware is up to date. You can check the manufacturer's website for any available updates or patches.
If none of these solutions work, you may need to contact the manufacturer's customer support for further assistance.
Hp scanjet 3970 will not scan slides with Vista
HP only have a basic vista driver for this scanner which won't give full functionality.
1helpful
How to scan a slide
Hi Arlene,
Have a look here:
http://files.support.epson.com/pdf/per248/per248bb.pdf
This is the quick reference card that would have been supplied with the scanner, scroll through the information to page 5 which tells you how to scan film or slides.
If you want the full manual and information then have a look here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=41624&prodoid=46253280
I hope that helps.
Mike
2helpful
2answers
Scanning neg
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
1helpful
Epson 3490 does not find the slide I put in the correctly positioned provided frame
Scanner incorrectly reads frame position on film
Yes there is
1helpful
Scanning slides with anoscan 4200F
have you tried checking for a firmware update from the manufacturer?
5answers
Scanner
There is glass platen and on its sides you can see the markings to place various paper sizes. Just follow them as per your paper size.
3helpful
Epson perfection 4990 photo scanner
3helpful
2answers
35mm Color Slides
Here they are for Mac and PC
If you receive a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
