go to settings, then "touch on display", then touch "when device is rotated", a screen should pop up, touch on "rotate contents of screen", it should now rotate.
Devices can be different, but check your Settings. Find Display. Make sure "Auto rotate screen" is checked. Or sometimes it may be as simple as powering the device off then back on.
Try going to Settings - Display and making sure you have Auto rotate enabled.... also settings - Accessibility might have the option as well, then turn tablet off completely for 1 minute then power on!
If the text is landscape and you want it portrait (or vice-versa) you must unlock the screen. Then when you have it in the position you want you can lock it again. Quoting from the onscreen manual,
"Swipe down from the top of the screen to see Quick Settings. From here, you can access volume, brightness, wireless options, or tap More to see other settings.
Locked/Unlocked: Tap to lock or unlock the screen rotation on your Kindle Fire HD. You can lock the screen to keep it from rotating when you tilt the device."
Sometimes there is a second option called screen lock that keeps the screen from rotating even though you have auto rotate checked. Check thru your setting to see if you can find this.
You've locked rotation. In portrait (home button at bottom) position changed rotation lock switch at right edge (top switch). You'll see Locked/Unlocked icon on the screen.
Facebook has privacy settings that allow users to prevent comments or likes on their timeline. You've encountered one.
