SOURCE: Whirlpool Ice Magic-No Frost Refrigerator (I'm guessing 30 years old)
look above the bottom kick plate, on the right middle, or inside the fresh food interior walls been a long time to remember this sweety machine loved it too everything where it was needed to be
SOURCE: whirlpool model-ER2MHKXPL02 serial-ES3330121 water accumulates in
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
SOURCE: my freezer is working but my frige is not cooling
wrong model # ,defrost problem. remove freezer panel, check heater, check limit switch while still covered in ice, if both ohm infinity, replace defrost timer.
SOURCE: No ice from GE model TFX20JRS/XWW side by side
I repaired it by replacing the ice maker motor gear.
