Microsoft Xbox 360 Console Logo
Anonymous Posted on Jan 07, 2011
Has 3 red blinking lights - Microsoft Xbox 360 Console
Anonymous
Level 2:
  • Expert 51 Answers
  • Posted on Jan 07, 2011
Anonymous
Expert
Level 2:
Answers
51
Questions
0
Helped
14195
Points
160
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Anonymous
Level 3:
Guru:
  • Master 501 Answers
Anonymous
Master
Level 3:
Guru:
Answers
501
Questions
0
Helped
155626
Points
1515
Do this function test and I can help you. Turn on your console, your 3 red lights are flashing numbers 1,3,4 I'd imagine which indicate a general hardware failure ( laying your console down horizontally look at your power button there is a circle with a line at the left side of it directly above that line is number 1, 2, 3 and 4 go in a clockwise direction) now press and hold down your synchronize button (the small button to the left of power) and then press eject 1 light will flash press eject 3 more times and you will have a 4 digit trouble code to determine exactly whats wrong with your xbox. Reply with that info and I'll tell you the problem
  • sltetzlaff Jan 15, 2011
    code if i did it right 4114 ?
  • johny b Jan 30, 2011
    how do you find out the code on the white xbox??? now 4 lights are flashing
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Nov 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
3536
Points
13
To fix the 3 red lights what you will need to do is stop the heat getting to the GPU and the CPU and to do this you can use a good Xbox 360 Repair guide or of course you can send it in.
  • Anonymous Nov 05, 2011
    http://fixurxbox.chri5123.hop.clickbank....
  • Anonymous Nov 03, 2012
    when i press the sync and eject button a code comes out as 0110. what does this mean?
Epson L361 Service Required Solution Red Light Blinking
The Epson printer red light blinking due to various reasons. The Epson printer light blinking when you have paper jammed, low ink tank, Epson printer printhead overloaded, when printer fuser not working and more.
Fix the Epson printer red light blinking error with simple methods:
·Clear Paper jammed in printer
·Check printer Ink cartridge
·Check printer network connection
Follow the more troubleshooting methods to fix the Epson printer red lights blinking issue.
TV SHUT OFF, HASPOWER, RED BLINKING LIGHT, WON'T TURN BACK ON, WHATS THE PROBLEM ?
If the red light is blinking, then it either does not have a good power connection or its in a diagnostic mode. The red light should be solid not blinking.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
I turn it on and set it to 375. Why does it just keep blinking?
blinking green red light Electric Kettles Questions & Answers ...
www.fixya.com > Forum > Tags > blinking green red light
Electric Kettles blinking green red light questions and answers. Ask your blinking ...the kettle lights up but won't heat up, just bought it, the on switch shows red, but it isnot working...what to do? ... Chef's Choice 677 Cordless Electric Kettle.
red icon blinking Electric Kettles Questions & Answers - Fixya
www.fixya.com > Forum > Tags > red icon blinking
Electric Kettles red icon blinking questions and answers. Ask your red icon ... Light will not stop flashing Even after descaling and cleaning thoroughly the red lightflashes. Any ideas? ... "On" switch blinks, kettle won't heat Our 4-week old kettle juststopped working. When we ... Chef's Choice 677 Cordless Electric Kettle.
1helpful
Came home and linksys only shows blinking red light.e3000.is it fried router
Which light is Red blinking, you should unplug the router, and wait about 2 min, then plug back, if you still see the blinking red light, it may be a bad Router if it is the power light,.
1helpful
2answers
My ps3 won't turn on and red light keeps blinking,
Read this:
http://www.prlog.org/10506996-ps3-red-flashing-light-causes-and-solution-revive-your-ps3-by-fixing-red-lights-blinking-yourself.html
3helpful
2answers
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
2helpful
2answers
Some keys on the keypad are not working, like the del key and the letter p
Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653
2helpful
3answers
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
2helpful
3answers
Red Light
slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply..
if in dry mode let the unit run for an hour and it will stop blinking ..
2helpful
Samsung ml-2850 Blinking Red Light
Change cartridge chip r paper pickup sensor
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
