I have a pocket dj that was given to me by a friend and I want to add/organize the songs on there. I purchased a usb cord and downloaded the drivers off the dell website but my laptop isnt recognizing it when I plug it in. How do i fix it?
If you find none of this has worked you need to try some other decvie
in the same usb port. If it is plugged in and operates correctly, you
have narrowed it down to the dj unit. Since the chord has tested good,
we should go to the unit itself. Four tiny screws located on the
outside of the case need to be removed in order to open it. Carefully
remove the hard drive, then the battery.
Now with the cable hooked up to the usb port you will use a meter to
check some voltages. Perhaps you have a friend who can help. The
batteries should read 3.6 VDC. Measured like that its not a true
indication of the state of the batteries, but tell us that the charging
circuit is probably working okay.
Put it back together carefully, making sure every connection is
properly seated and there is no damage. Try it again, making sure you
hold down the button for 3-4 seconds. If you have done all of this, the
problem is electronic and at a component level. Suggest you take it or
send it to the repair shop dell has.
Your
player appears as a USB mass storage device in theMy Computer window. You can organize
files and transfer music to your player while connected via USB connection.
1.Click
and highlight one or more songs to transfer between your player and your
computer
2.Use
drag and drop actions to transfer music files and folders to your player
3.Organize
your music in folders. Your player will play your music folder by folder so
that you can organize your music by artists and albums. You can drag and drop
entire folders to your player. Your player will play the music files that are
not inside folders first followed by the music files inside folders
