You will probably need an assistant to remove your watch.
If you still can't get the watch off, let your assistant use a small screwdriver to remove the spring loaded pin that holds the strap to the lug of your watch.
( This can be done by putting a small tension on the strap pressing the screwdriver against the pin and pushing it in the desired direction. Some practice may be required!
