Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
i had same problem, i brought it to Duke Electronics, They fixed it in one day, Check there website for address infomation www.dukeelectronic.com
Add a CommentI am in the military and deployed overseas, so parts are limited. But we are a bit tech savy. We have a Electrical Engineer in the office and I am an electrican working on my degree in Electronics Engineering Tech. We have a Sharp LC-52D64U and it seems to have a power supply problem. We get the following code: Power>flash then Power&OCP>flash then repeats. I didn't find any bulging Caps. Will the problem be on the main Power Supply or the Inverter board in the middle of the back of the TV? Thanks!!
Could have bad CPU data firmware problems to the main signal Tuner board,but Sharp Corp.never admit this and never have upgraded firmware software for the tv series known as Aquas from 40 to 52 inches screen.
SOURCE: Sharp 46" LC46D62U suddenly will not respond to remote or manual
check for bad capacators on the boards they often have a rise in esr and confuse the chipsets
