Hi there - the door of my washer won't open. I got an ND error reading, indicating a drain problem, and now the red lock sign stays on, and the door remains locked (with a full load of laundry inside!). I have called Samsung technical support and was told that they would get back to me in 5 days or so! My son's baseball uniform is inside, and he is desperate to get it out in time for his game tomorrow! Any ideas how to override the locking mechanism?
Thanks so much!
SOURCE: My washing machine is "eating" my clothes!
ck the plastic fins in basket for broken/sharp areas
SOURCE: maytag front load washer mah8700a power dead clothes stuck inside!!
take out he screws that are under the detergent tray door and remove the whole detergent tray assembly, there should be a plastic chord with a loop on the end; pull it hard to unlatch the door.
SOURCE: Door won't open on Samsung washer
Your water pump probably has debris in it. Remove the back center cover. The water pump is right there. Thread the drain line back through the machine and put the end in a bucket on the ground, most of the water will drain. I used towels to deal with the rest. Remove the water pump and open it up, I found a quarter. Reinstall and if you found debris the machine should work. It took me 1/2 an hour to do this, not worth calling for service.
Hello & Welcome to FixYa
ND error in your Front Load washer
indicates no drain issue. To start with check the drain hose for any clogs and
try cleaning it, then check restriction in drain pump assembly or loose wire at
the pump. Please get back to me if you have any other questions.
Kevin
same problem, error message nd, called lowes, we can't find our warranty papers, due to moving and husbands work uniforms are locked inside.
