SOURCE: TV Repair Assistance needed
FLP stands for -- Front Lock Panel - I found it in a friends RCA TV manual. It is a lock you can place on the tv front panel buttons. When this is locked you can only use the remote. So once I knew that I went to RCA Service Center and ordered a new remote.. problem solved. So since your person couldn't even understand my problem, let alone solve it. I would like a refund please.
Thank you
SOURCE: Timer/Standby light blinks but no picture or sound when power button is pressed.
I'm having the same problem. My stand-by light blinks 3 times though. The tv clicks as if it is going to turn on, but it never does. Is there a simple solution to this problem?
SOURCE: RCA 32444
While it could be that the power supply has failed, it's more likely a problem within the Horizontal sweep circuit. Might be the Horizontal output transformer, or, the transistor, or both.. An exception would be a shorted diode in a derived supply from the horizontal sweep, or a short on the load circuit of the supply. All of the parts are soldered in. There is no "power supply" that can be removed and replaced as a unit. If you have no electronics experience, stay out of the TV. You have no business inside of a box that when working develops something to the tune of 30,000 volts. Not just a little dangerous, it can kill. If you have the experience, fine, if not, consult an electronics servicer.
