Lenovo IdeaPad S10 - 42312BU Notebook Logo
Posted on Jan 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Broken LED - Lenovo IdeaPad S10 - 42312BU Notebook
Anonymous
Level 3:
Guru:
  • Master 679 Answers
  • Posted on Jan 06, 2011
Anonymous
Master
Level 3:
Guru:
Answers
679
Questions
Helped
168749
Points
2165
If its a broken LED you need to call LENOVO HARDWARE SUPPORT to replace the LCD
1 877 453 6686 option 2.thanks
My message waiting indicator light on my panasonic KX-T7667 doesn't light up when I have a message waiting?
If the red message/ringer lamp never lights up, the solder connection to the LED may be broken, or (more rarely) the LED may have broken inside.
I have a Seiki 46 inch flat screen, and now no power. Kinda hoping this is something simple, 2013 manufacturer date. Bought this used, so no warranty. Any ideas?
How To Fix A Broken Flat Screen LCD LED TV With Lines or Cracks ...
removeandreplace.com/.../how-to-fix-a-broken-flat-screen-lcd-led-tv-with-lines-or-cr...
May 20, 2015 - If you have a broken LCD LED TV Screen that has any type of ... To make contacting your TV manufacturer easier, we have included links to most ... It can be done but is not recommended if you have no knowledge of ..... Now can you suggest me if I can get it repair (at which cost) or I ...... Hope you can help.
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Do not my printer initialize & red light glow
LP-365W On Line LED Is Solid Red - samsung product ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsImportant: Before you perform any type of service on your printer that requires you to... Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ElectronicsDec 2, 2014 - Important: Before you perform any type of service on your printer that ...Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ML-3561N Laser Printer Initialize - Questions - Fixya
www.fixya.com > ... > Samsung > ML > Samsung ML-3561N Laser Printer
ML-2570 Samsung printer having problem orange LED is blinking ... initializing stage green LED glows continuosly,After initializing Printer green LED turn into ... the red light remains on when i switch on the printer.. and it doesnt initialize the ...
Samsung glow plug Printers & Copiers Questions ... - Fixya
www.fixya.com > Forum > Tags > glow plug > Printers & Copiers
Printer Problems...red status light glowing I bought a Samsung CLP-310W a ...Samsung printer having problem orange LED is blinking in initializing stage ...
Reset for Samsung ML-1660 ' FixYourOwnPrinter
Laptop charging problem
check if there's a led on the power adapter and if yes, check if it's lit when plugged in.
if there is a led but it's not lit, the power supply is broken.
if there's a led that is constanly on, but the pc doesn't charge, it could be the battery (very common with HP laptops)
if there's no led on the power supply, remove the battery from the computer, connect the power and see if the computer works. if it does, the battery is broken and should be replaced.
if it doesn't, check the power connector to the laptop. there's a fine pin in the middle of the connector that may be damaged. if so, replace the adapter.
if not, it's still not clear if it's the adapter or the motherboard of the laptop and the only way of finding out which one it is, is replacing them one by one.
I have a broken Dell Precision 470 Workstation. The symptoms are as follows: Won't power up; Flashing yellow power LED on front panel; Blank STR_LED on motherboard; Yellow AUX_PWR LED on motherboa
Flashing front powerlight is often a result of a faulty powersupply, try another powersully on the pc and see if the problem gets solved. I've seen a few of these cases personally.
2helpful
How to connect my samsung led tv to samsung galaxy tab through all share
how to connect my samsung led tv to samsung galaxy tab through all share
Lcd led not working.
2 possible cause, one is led IC on main board an the other is a broken wire to lcd led, with by the way it cane be changed without replacing the lcd
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
