Dead appliance, power on wall outlet. YOUR
SAFETY IS PARAMOUNT! Attempt
this only if you are competent. If
your appliance has absolutely no functions at all, remove it from the
mains supply, remove the case and see where the mains lead goes in to
the appliance and follow the cable until you find the main fuse.
ONLY
USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual
cause of this fuse failure is the door switches are contaminated or
sticking. Check the door switches before putting power back on to the
appliance.
Hope this helps.
I have taken of case and traced mains lead, but do not see any fuses. The mains leads go to a transformer/capacitor and then go 2 seperate ways into small connectors (prt no 03 2539 limiter temperture). I have photo's of these and the cables if i can send/email them somewhere.
I have searched and searched but am unable to find a service manual for your microwave. There must be an internal fuse link as someone could cut the 13A plug off and hard wire it to a ring main.
The cause will be either a jammed door interlock switch or the transformer.
It is so annoying when the simplest of equipment is out of our reach!
Maybe the fuse is built into the transformer as most transformers in HI FI and power supplies use an internal fuse.
Try relisting your query as I can go no further at the moment.
Good luck with the repair.
