It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive. If this does not work, contact Verbatim for a solution, these USB flash drives have lifetime warranties.
SOURCE: How do I turn off the write protect on the verbatim 4gb flash drive?
I solved write protection on my Verbatim store 'n' go 1 GB by this program "HT203 Handy Steno 2.0 Repair Tool" which format FLASH DISK from http://emea.apacer.com/en/support/downloads.asp . I know its different manufacturer but its working.
SOURCE: verbatim 4gb flash drive write protected error
your problem can not be solved, u can only buy a new one
SOURCE: cancel ''write protect'' on USB memory stick
If no physical switch, then check the software that came with. Some sticks have a software component that recognizes when you plug the stick in and gives you options for viewing and launching applications from the stick. There may be controls you can use to change the write protect.
If not, or you can also try, opening a view to the stick from Windows Explorer and just delete files from there as you would from any drive. Windows will prompt you to confirm delete. I wouldn't delete any auto-load or setup apps that would be used to connect to another computer.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
SOURCE: my Verbatim 4gig store and go usb stick in stuck in RAW Format
right click my computer, manage. go to disk management and delete any volumes on the flash and set back to basic disk if it's dynamic. format fat 32
