Let me break it to you: XP is dead. It's a new century. Download a nice Linux distro to a flash drive or DVD and try it out. Try a couple. Install the one you like. If it doesn't work or is erratic, your hardware is dead. Time for a new machine, anyhow.
I have a 6 year old eMachines sitting right here that I got for free, which is the only reason I still use it.
SOURCE: Don't know how to reformat my emachine T5010 desktop PC
no just put the cd/dvd in the drive and follow the instruction
SOURCE: eMachine recovery disk won't work invalid serial keeps restarting
Restart your computer and as its starting hold F8. This will take you into system restore. Choose Factory Default Restore. This will take your computer back to its original state when it was purchased. You will lose all files that were previously in the unit.
SOURCE: T6524 bios update needed
This isnt necessarily a bios problem mate , its just windows got corrupted during the power surge. Use the link below to do a repair install. Note , repair installs do not erase your personal files or setings or software !
http://michaelstevenstech.com/XPrepairinstall.htm#RI
Hope this helps you
If you found this solution helpful , please rate below
Kind Regards
1234s282
SOURCE: Windows doesn't recognize recovery partition after os reinstall
The issue you are having involves using multiple systems,...If your emachine came with vistan and you installed xp, you voided your warranty status...However remove your dual boot and stick to vista if you wanna keep your restore partition working properly.....On a side note theres usually conflict with running OEM OS's on dual boot...typically it doesnt work and if it does it doesnt work like you want it to! so here is what you can do..Call Emachine up and fib to them a bit (just alittle) tell them that you cought a nasty bug and it messed with your restore partition and now you cant restore your pc....request the factory programing discs (if you ask nicely they'll hook you up 99.99% of the time) you get the discs so you can reprogram the pc to factory spec if you ever wanted to. Now use a retail version of vista and a retail version of xp. and create your dual boot, feel free to remove your restore partition if you want (cause you have the factory programing discs if you wanna go back to stock stuff YAY) I hope this helps!
Testimonial: "Highly knowledgeable and an awesome guy for taking his time to share his expertise with the pc community. Thanks again!!!"
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
i have read some reviews on your monitor
So the ex-hubby calls me with his woes - his eMachines T3124 is having problems. Seems that when he cold boots in the morning it hits the "E" splash screen and then just goes to black screen. No bios boot screen, no boot to windows. Everything sounds ok though. After a few restarts it boots ok. So, first trouble shoot is to replace the 180w Bestec power supply with a salvaged 300w Hippro from my T6420 (which was replaced with a 500w) - the one I replaced the mobo on. Works great ... for one night. Next morning I get the frantic call - now he gets nothing after the "E" splash but white wavy lines, but the computer sounds like it's running fine. Ok - ok ... think, think. First thought was maybe the onboard graphics have gone, next thought maybe the mobo is going ....
What is the next thing we do after trying a known, good power supply? Try another working montior. I had him try using a trusty older CRT monitor and Wha-Lah! After less than 3 years the E17T4 LCD monitor had failed. Most recent crisis handled. This little incident has made him realize though that he needs to burn all his picture and videos to CD. Scared him to think he could have lost them. Today's reminder? BURN your pictures and videos now! You never known when something might happen. And eMachines monitors are ****.
hope this helps
