It is not the player you need to reset, it is the rental DVD's. They are encrypted with a code to limit the amount of time they can be watched, thereby protecting them from being stolen or not returned. Send them back to the rental company and rent the same movies again. That is your only solution. Your player will play whatever is put into it. I hope this helps.
Either the Laser needs to be cleaned or it needs to be replaced. To clean, purchase a DVD player cleaner that uses fluid. roughly 20.00 run it a couple times and test. If it works, great. If it doesn't, replace the unit. It's cheaper than the repair. Hope this helps
This is normal as the device is checking for a disc that may be loaded in the unit. The fan should also start running when it is powered on. If the noise continues and can be heard over normal volume levels, this may be a fault.
