SOURCE: Hotpoint Aquarius DWF31 Dishwasher Inlet Valve
Please verify that the hose screen is not plugged.
3.8k is good.
Did you try putting your hand carefully on the body of the valve to check for the clicking sound/vibration at the solenoid?
If you here/feel something, you may just have a plug-up.
Otherwise if there is no noise and since the solenoid coil checks out, You should also check to see if there is voltage to the solenoid coil.
The solenoid could also be stuck and a few taps could loosen junk from it.
Always observe safety!
If there is voltage, by putting a meter across the coil terminals, then you do have a stuck or shot solenoid and the entire valve/solenoid assembly should be replaced.
SOURCE: electrolux Dishwasher 24 " not
if i was at your home as a repairman this is what i would do.if your water pressure was good at the kitchen sink,i would turn water off to dishwasher undo water connection at the fill valve,and place water line in a bucket and turn on water.if ok and still not getting water then prob with fill valve.soooo you have a new valve,did you check the water pressure to the valve? if yes good because then you also flushed out that in coming water line.because[and i have done this a few times]if not flushed their could have been minerals setting in that supply line so when you turn the water back on it pushes that stuff into the new water valve screen and blocks it up also.if your getting water then its trying to do its job,it just cant get enough water and the timer times out so no more voltage to the water valve.thats a lot said but there no mystery to it.the timer allows for lets say a 70 sec fill at 40 lbs water presure ,seventy seconds up that's it .the float only stops it from flooding,too much water.it dose not tell the machine that there is not enough! so because its letting in some water that tells me the float switch is closed[and it should be]leting the voltage to the water valve.the water valve has to let in enough water then.i know i mixed up words a bit but i hope this helps you understand whats happening.God bless ,if you need more advice you can email thru FixYa tom
SOURCE: Dishwasher will not fill up with water
did you chek the level micro switch thats in serie with the intlet valve
check the following- remove the wires from the fill valve.close the door and start the unit.u should read 120 v as u start the unit.if u read 120v then fill valve is bad.if not then chk and make sure the float is sitting completely down and float sw is closed.the power to fill valve goes throug this sw.if all is ok and still there is no power then u may not be getting power from cntrl board and control board could be bad.but that rarely happens.turbidity sensor does not affect the fill operation.good luck.
