If you have a working internet connection you only require one switch plugged in, with all 10 machines plugging into that switch. They should pick up IP addresses by DHCP being done by your router. What do you mean by dumby addresses - APIPA 169 addresses?
When your 10 computers are connected to the switch, just make sure your ethernet cable is plugged into the ethernet port. The computers should then have a internet connection
SOURCE: Linksys routetr problem
HI,
The problem can be caused, because of two reasons, one the router profile on the computer has got corrupted and second the router itself. Have you tried resetting the router to factory defaults.. Caution: all wireless security settings and user name and passwords would go back to factory defaults.
1.Disconnect all cable from the back of the router.
2. Shut down your computer and the DSL box
3.Press the reset button, using a paper clip at the back of the router.Keep it pressed for 5 seconds
4. Disconnect the power cord to the router
5. Switch on the Dsl box, wait for the lights to stablize
6. Reconnect the interenet cable and the power cable to the router and power it on.
7 Let the lights stabalise on the router and power on the computer.
Check if that resolves the problem, if not we might need to update the router.
Thanks
Proton
SOURCE: can't get two computes to run internet at the same time
If you login to your router and make sure DCHP is enabled, and then go to Services (services.msc) on your computers and make sure that the DCHP Client is running, it'll automatically assign IP addresses for your computers and they'll both connect okay.
Hope this helps
Chris (ziraffa)
SOURCE: Linksys EZXS16W switch, ports 1,2,3,4,9,10,11,12
I can give you the full manual of that product bro but you should have to install a foxit reader in order to read the file or the manual. First intall this software: http://www.mediafire.com/?nyowk0a5yqm Linksys EZXS16W manual: http://www.mediafire.com/?tgkdwnkjz1g
