Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
My D-Link WBR 2310 router signal keeps dropping. Is this a problem with firmware?
  • D-Link Master
  • 6,487 Answers
This type of problem can be related to a firmware issue on the router and what you can do here to try in correcting the problem is to do first some changes on the wireless settings of the router like the channel and play around with it and look for a stable channel but if still the same problem do a firmware upgrade on it.
Posted on Jan 05, 2011
6ya staff
SOURCE:
My internet via ethernet works perfect, but got dropped a lot via my 3 years old D-link WBR router. Is this an indication that I should replace my router?
Try changing channels, it could be RF noise from some near by device, you could also try updating the firmware to the latest version, some times moving the router in a different location could help.
Jan 04, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Have dlink router 1310 when switched over to jumpstart no longer usable
There are multiple versions of both of your routers, you can click on your version and try there tech info from there. If you have no luck, just post the right versions here and I'll see what I can do for you.
There are multiple revisions of the WBR-1310, each with revision specific drivers, firmware, installation guides, and other resources.
There are multiple revisions of the WBR-2310, each with revision specific drivers, firmware, installation guides, and other resources.
Go to there support page and click on your model.
http://www.dlink.com/products/default.aspx?pid=WBR-2310&tab=3
Dec 22, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Win7 & vista keeps losing connection with WBR-2310 router
Signal strength drop or fluctuation are common causes of RF interference.
Try these basic troubleshooting steps:
• Change the channel on your access point or wireless router.
• Change the location of your wireless products. Subtle changes (2-3 feet) can make a big difference. Do not put the access point or wireless router in a cabinet or enclosure.
• 2.4GHz phones, X-10, and bluetooth devices will interfere with your wireless network. Change the location of the base for your phone, or downgrade to 900Mhz phones, or upgrade to 5.8GHz phones.
• The wireless signal will degrade (or die completely) when going through brick (fireplace), metal (file cabinet), steel, lead, mirrors, water (fish tank), large appliances, glass, etc.
If your wireless connection is only dropping during large file transfers or when a large number of wireless clients are connecting, change the preamble on all wireless devices to short.
Nov 11, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Low wireless signal WBR 2310 on signal strength
when a wireless router has signal strength issues, there usually is a firmware upgrade, which you can find on the manufacturer's website, that may solve this problem by upping the db of the wireless transmitter.
Apr 20, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Wireless signal stops working after some period of time
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Sep 26, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
My wireless network gets dropped
HI! that is correct.. your device wont connect bcoz you change the wep, ssid name etc on the router.. if the security settings is change from the router and your wireless devices have the old settings it wont work and it will not connect.. you need to enter the new wep, ssid name etc to the wireless devices in order to connect to the wireless network..
Jul 10, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
D-link WBR-2310 has serious drop out problems
I'm pretty sure that downgrading the firmware to 1.0.3 will work. I had been running at this level for quite some time and for some reason I decided to upgrade to the latest version which started the problems for me. I am downgrading to this now and I expect better results. All of the firmware versions are available at http://www.dlink.com/products/support.asp?pid=470&sec=0. You pick the right hardware revision. PLEASE NOTE: Save off/remember your settings as when you change the firmware it resets all of them back to system defaults.
Dec 12, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Issue with WEP/WPA (WBR-2310)
Well if you updated the firmware and your still having issues contact dlink for a possible replacement it sounds like the hardware could be bad or you can try uploading same firmware by crash reseting router and uploading latest firmware again.
Jul 14, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
259 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
