In the preamp section for the center channel find the C3200 transistor - should be Q108C. Try heating it up (holding a soldering iron up against it for a minute usually does it). Then see if the unit turns on ok. These transistors have a tendency to get leaky when they are cold, but work ok once they warm up a bit. Replacing it should fix your problem.
For something to trip the protection circuit, it must be shorting somewhere. My bet would be an output transistor or IC, but if you think they are good, a bad capacitor would also do the trick. If the top of any electrolytic looks odd or there is any stuff coming out of them replace them.
You might want to look at the "Bad Caps Forum" website, it lists known capacitor makes that are known to cause trouble. If you see any them replace them.
SOURCE: Reads PROTECT on the display of my Onkyo TX-SV525 ???
HOWDY, NOW YOU COULD TRY THIS ONE: POWER THE RECEIVER UP , THEN PUSH&HOLD !THE VIDEO 1 BUTTON, THEN TURN THE PIECE IN THE OFF (STANDBY MODE ) ,IT WILL SAY "CLEAR SO IT SHOULD BE BACK TO IT,S ORIGINAL FACTORY SPECIFICATION,S. SUCCES ! AMSTERDAMCOWBOY-HOLLAND-NOW FLORIDA! 4-EVER
SOURCE: Denon Receiver flashed PROTECTION and stopped working after plastic smell
i just had the same thing happen to me what did you do to fix it?
SOURCE: I have a SX-780 receiver.
This unit needs an overhaul. There are probably poor solder connections &/or defective parts inside. Expect a parts cost around $20-$40. Add in the local labor rate for the total cost. These are nice units and are worth the repair cost.
Dan
SOURCE: Denon AVR 2106 Protect Mode
Ok,
I will will help you with this, but you must follow my instructions. These are not easy unit to repair, and your troubleshooting technic may have even caused more problems. You should never power on a receiver with connectors unplugged. Since the 15 pin connector is used for the audio signals only (CN559) you may be OK, but please do not do this anymore unless you are willing to create a lot of smoke.
Since this unit does turn on without that one connector plugged in, I will assume that you do not have a blown channel even though it is the most common reason for these to go into "Protect Mode" which is what yours is doing. They go into protect mode to keep the receiver from causing more damage to the circuits and to prevent fires.
I think the most likely reason your unit is going into protect mode is because the negative 15 volt regulator on the main board is bad. This regulator is located by ref # IC102 and is on a small heat sink in the power supply area of the main amp board. Since you have the manual for this unit you should be able to find the part number and location very easy.
The second most likely reason for your problem is a resistor, ref # R184, it is a 10 ohm 1 watt resistor and it is right next to the pre-amp board on the main board. It is near CP501 but on the other side of the pre-amp board towards the output transistors a little. Check this resistor first with an ohm meter, see if it is at 10 ohms. If not, get a 10 ohm 1 watt flameproof resistor and replace it. Then make sure everything is plugged in right and try it again.
If the resistor is good, then go to the voltage regulator, you can check it by measuring the voltage at resistors R145 and R146. If you look at the schematic for that area, you will see that those resistors are connected to both the positive 15 regulator and the negative 15 volt regulator. One side of R146 should measure -15 volts and the other side of R146 should be at 0 volts. Then measure R145. You should have +15 volts on one side and 0 volts on the other side. If the voltage you measure there is not within a couple of tenths of a volt either way, change the voltage regulator that is bad. If all you get is positive voltage on R146 and no negative voltage, then IC102.
Now you are probably wondering, how can you check those voltage if the unit is shutting off right away. Here is how. Have you meter probes in place before turn the unit on, watch the meter while is is turning on. You only need a few seconds to check each one. Check R146 first, then after the unit shuts off, check R145 when you turn it back on again. This is much safer than unplugging connectors and letting the amp idle with unbalanced voltages which could cause an extreme current draw if left on too long.
If you can not verify any problems with those two things above, then you really do need to check the amp circuits. You can do this with no power connected, but you must take out the main board with the big heat sink. Once you get it out, check the output transistors and start with the pair that is located at the inner most spot of the heat sink. The area close to the display and CNT board. That is the most common channel to go bad. If either one of those transistors mounted on the big heat sink measures shorted of very low in ohms, that is the bad channel. If you have a bad channel, there will be many more parts to replace, I will let you knwo what those are if you find any shorted output transistors. You can not check the amp circuit any other way, you will only be getting a reading across the relays if you try to check it at the speaker outputs. The speaker relays never open unless the unit comes out of protect mode first.
Let me know if I have explained this good enough for you, if not I will give it another try.
Good luck,
Dave
SOURCE: connection problem with HDMI cables on Denon AVR-589
Hi dmsgolfer22,
If your Time Warner Cable box is old enough that it has a DVI output it may have HDCP (copy protection issues) with the receiver. If you are having to use a DVI to HDMI adapter to connect to your receiver (output from Cable Box to input on Receiver) then it's very likely your cable box may have may not output the signal because it detects the HDMI repeater in the receiver.
The two best options to correct this are:
1. Connect the DVI to HDMI cable directly to the input on the TV, you lose the convenience of the video switching in the TV, but it will solve the problem. Then connect the digital audio output from your cable box to the receiver, although you've probably already done this.
2. Contact your cable provider and check into the possibility of them swapping out your cable box for a newer model that would have an HDMI output. This would be the best option since the HDMI output on the cable box would give you both the Digital Audio and Video through a single HDMI cable.
Let me know how it works out for your, or if you have any questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
