SOURCE: setting dpi on canon ixus 800 IS
You can download manuals here.
As dpi is generally a printing specification, the size you set on your camera depends on what size prints you want to make. If you want to print 4" x 6" prints at 300 dpi, you can set the size to M2. If you want to print 5" x 7" prints at 300 dpi, set the size to M1. Anything larger, set the size to L. With L selected, an 8" x 10" will still be about 300 dpi, but any larger print will be at less than 300 dpi.
SOURCE: want to change the language
Make sure the mode dial is in playback mode and the camera is turned on. Press and hold the Func/Set button, then press the Menu button. This will bring up the language selection screen. Release both buttons and use the arrow keys to highlight the desired language. Press the Func/Set button to select.
SOURCE: Web cam set up on Canon IXUS 400/POwershot 400
For any self respecting programmer/hacker, the instructions at http://users.utu.fi/paanni/camera.html maybe close to what you want.
SOURCE: ixus 800 is lcd screen wont work in live move but give image afte
you need to page through MENU and find section "reset all" - accept. and screen should back on.
