Does it come back after your done adjusting? Or do your have to do something else to get it back? If its just during adjustment then its probably the design of the speakers.
Saw picture of speakers online and they have some complex electronics. I think the speakers are defective and are not easily fixed. If you have the receipt and can return or exchange them. Do that.
can u tell me where can I buy volume control nob becoz my warranty period is finish
I looked on ebay, with no success. I would contact the manufacturer. Is it something that goes away after you adjust it? If so I would live with it as it could be something inside the subwoofer. The Sub houses the amplifier and electronics for the whole system.
Some people solved their knob problem with a little lubricating oil or WD-40 or petrol (I don't recommend petrol, cause their may be heat and petrol can ignite the knob... LOL)Since I can't get any petrol or other similar lubricants, I used a lubricant made by mixing coconut oil and kerosene which was there in my store room and it worked like a charm.
SOURCE: Sound through right speaker is not proper Creative Inspire M2600
This sounds like an electrical problem in the speaker circuitry - between the speaker(s) and the control knob.
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
hope this helps
