Hello
You haven's specified nothing about the picture. Picture is Ok and there is no sound I thinks and posts this solution
Either your TVs speaker or its sound out put ic has damaged. To check it and conifrm you just do this first. There is a stero headphone socket on the front panel of your TV. Insert a headphone pin inot it and listen whether there is sound output come ffrom it or not. If there is sound output from the headphone socket, and not from the speaker, be sure taht the speaker is out.
If there is no sound output from the headphone socet, wither your TVs sound output ic is damaged or it doesn't get proper voltage to go on. It is very easy to locate this IC, as speaker wire goes directly to this section. Just follow the speaker wire and locate the IC, usually screwed on to a metal heatsink. Check its input voltage. If there is no voltage to that IC, check the track associated with that pin. If there is voltages and still not works. first resolder all the pins of that IC by applying a little more solder, whout shorting the adjecent terminals. If this does not helps, replace that IC with same type and number. OK.
yes
i change the ic with same name and number its working
thanks for the suggestion
