Apparently seems like your laptop is facing heating problem & its because your cooling system including fan inst working properly. You need to check if your fan is running at adequate speed and also there aren't any dust particles stuck in head sink on either side of your laptop. All you need to do is just to use an air blower and clean the fins of your heat sinks to make the air flow properly. Good Luck
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust. Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail. A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust. Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust. Check the CPU fan to see if it spins freely, if not replace the fan.
I would check to make sure that the heat sink compound between the Heat sink and CPU has not dried out. This paste is supposed to stay somewhat soft and conducts heat away from the CPU. It can be purchased at Best Buy if you need some. Had the same problem recently with a Acer desktop. When I started it up the CPU fan just took off and would never slow down. Never could get windows to load either. Cleaned off the old compound using regular alcohol and put in new compound and it was quiet as could be. Windows loaded right up and it is working great. Heat is a major issue with the speed of CPUs these days. Hope this helps
Inspiron 5160 is probably at least 3 or 4 years old. If it is running slow, (and maybe fan is running all the time and fast) you might need to check if the heat sink/fan assembly is in need of cleaning. You have to remove this assy from the laptop, and remove all the accumulated dust and gunk from the INSIDE of the copper fins. Inside meaning remove the fan from the assembly and with a fine brush, GENTLY remove the gunk from the fins, or with the fan removed, try canned air.
Start by cleaning the fan and heat sink. Dirt or dust build up can cause them not to work as efficiently as they should. If cleaning doesn't fix it, you might consider replacing the fan and heat sink or purchasing a cooling pad.
My guess is that CPU fan, it there is one, is not working properly and your computer is heating up. Is it turning off, too, occasionally after a period of time? Suggest a new CPU fan.
