Unplug the unit to reset the console and then plug it back in. Do this multiple times if console error message still appears. 2)if the problem persist :Please refer to the User Menu section of the manual.
To Get to the manager and check for disabled items. To enter the Systems Options Menu: 1. Press SELECT WORKOUT. 2. Touch the Life Fitness logo in the upper right hand corner of the screen three consecutive times go to configuration Configuration Allows authorized personnel to access all configurable settings of the unit. Configurations which should only be changed by qualified technicians are password protected. Manager Vivo/Network Manufacturer , Create Your Own Media Center , Clock Custom Workouts Touch Screen Configuration Export / Import Settings The console manual will show you all the default values . https://www.lftechsupport.com/c/document_library/get_file?p_l_id=27605&folderId=483177&name=DLFE-28306.pdf
This is because the function is activated Immobilized feature. " now you must do the following: Press and hold the SPEED Down Arrow Key and press the Pause Key to toggle ON / OFF. and go!
If its growling then the incline motor is on its last leg. All incline motors have some degree of noise my only suggestion is if their is a Gym in area call them and see if they have Life Fitness treadmill don't worry if it is not the same model.
The motor have not change much you should be able to gage noise level on a few of the units.
They do not have a total mileage or hour usage if this unit came from a gym a loose figure of 20 to 25,000 miles or 3 to 5,000 hours give or take.
If the walking belt has shifted to the left, use the Allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left rear roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking
belt is centred.
